hi
i use Avidemux with x264 encoder to convert satellite streams (TS) into MKV.
1. is MKV a good choice for the destination format while using this encoder? isn't it better to choose AVI? (the combobox under Format)
2. i do it for archiving the streams. we have only mpeg1/2 player device. when i want to convert them back to mpeg (preferably mpeg2 instead of VCD not to lose much quality), what converter do u suggest?
thx
Hello there,
my first remark (unfortunately this is a comparatively old thread) is directed at redwudz and Noahtuck: Why would you abuse a user and close a thread, (this: https://forum.videohelp.com/threads/343561-901123-in-Avidemux-Add-to-Joblist-causes-pro...lose?p=2141218) because it has - again: unfortunately - the same no. in front of the title as this one? The questions asked here and over there are completely different.
I could have done with an answer to the first (linked above) thread, thank you. After all, we are told not to use the same thread for different types of questions/subjects....and a sensible rule it is, too.
Or should I post the question again elsewhere?
EDIT: Found an open thread dealing with this, hope someone knows a solution, thanks. -
Because we are not perfect. Please contact us instead of digging up this.
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 6Last Post: 8th Jan 2013, 04:53 -
What best converter to convert MPG to FLV/H264?
By Leo99 in forum Video ConversionReplies: 6Last Post: 21st Apr 2012, 11:16 -
901123 - in Avidemux Add to Joblist... causes program to close
By hamidi2 in forum Video ConversionReplies: 2Last Post: 14th Feb 2012, 00:49 -
Is x264 a codec or encoder or converter or format or what?
By hech54 in forum Newbie / General discussionsReplies: 61Last Post: 25th Dec 2011, 12:01 -
SIMPLE free flv to mpg converter
By Traveller in forum Video ConversionReplies: 10Last Post: 20th Oct 2007, 21:02
