I have a couple of movies that both have these files: MKV + IDX + SUB.
I would like to merge them.
How do I do this? I am looking for a solution thats easy for anybody - even me, please.
Thanx.
\\ jan
Ps. Can "mkvmerge GUI" do the trick?
Yes mkvmergegui can do it.
But what are you going to play it on? It might not support mkvs with switchable sub/idx. -
I don't know what "switchable sub/idx" is/means.
I have a lot of movies on HDD that I play via WD TV LIVE on my TV. The ones I mentioned I can play because the 3 files all have the same names and they are all in the same folder.
It would be al lot "neater" if all my movies were "1 file movies". -
It means that they are embedded in the mkv and not burned in.
The wdtv live supports it but maybe not perfect see http://community.wdc.com/t5/WD-TV-Live-Firmware/Color-palette-issues-with-MKV-embedded...les/td-p/28050
ANd when you use mkvmergegui be sure to select File->Options->Disable header removal compression first or the mkv might not work on the wdtv. -
I tried to merge the 3 files with mkvmergegui (again) and I did as you suggested above,
I can play the moviefile, but there are no subs.
VLC - same problem!Last edited by dazler; 13th Feb 2012 at 09:48.
I solved it with mkvmergegui. It worked the third time around - my bad.
Thanx Baldrick.
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 21:22 -
I want to know how to put IDX on MKV
By hotboy87 in forum SubtitleReplies: 5Last Post: 13th Mar 2010, 13:57 -
Can't display embedded Idx/Sub (softsubtitles) in mkv.
By dsteff in forum SubtitleReplies: 1Last Post: 23rd Nov 2009, 23:01 -
Adding .idx and .sub to .mkv ripped by dvdshrink and handbrake
By theredlaugh in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 11:11
