Alright, since I just want to see if this will actually work and if the quality is good enough, I want to try and hook up my old stereo to my TV.
I have a Sony Bravia. These are the specs:
http://www.televisioninfo.com/specs/Sony/KDL-32XBR9/108409.htm
I have a Sharp Stereo. These are the specs:
http://elektrotanya.com/PREVIEWS/63463243/23432455/sharp/sharp_cd-c3900_sm.pdf_1.png
From what I can tell, the audio OUT for the tv is RCA, and audio IN for the stereo is RCA too...right?
Or am I wrong?
Do you have a cable box or Directv receiver?
As for the question, yes, both should be RCA type. You could go from TV Analog out to the Stereo Aux input.It Started In Texas -
Yah I have a cable box. It's a samsung cable box that I used HDMI with, don't think it's too much help.
So I just need a dual RCA cable or is there an easier way? Any recommendations since I think wire quality is a factor? -
Yes. I just want it so I can use the stereo's speakers instead of the TV's speakers. Whether it's for TV, PS3, etc.
I use RCA for my audio. I've tried Digital Audio Cable, I prefer RCA. I think that would be your best bet.
It Started In Texas
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 10:19 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 23:24 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33 -
Does the HDTV stereo spec contain dolby pro logic information?
By yoda313 in forum DVB / IPTVReplies: 9Last Post: 3rd Sep 2008, 06:55
