    Jan 2012
    Budapest
    Hello!
    Are there any software which have lossless output (huffyuv etc) and can transform the Progressive Segmented Frame videos into real progressive video material (like the weave type -lossless- deinterlacer do)
    I've only mediacoder, which can use CoreAVC codec as "video source". (deinterlace mode: "Weave" option) With the help of Coreavc video source (weave option), the PSF videos become transformable into real progressive video without the quality loss of deinterlacers. The only problem of mediacoder is its Huffyuv codec (tons of serious bugs) and its MKV container format. In normal case, MKV is the world's most tolerant container format, however in mediacoder the MKV format is the most intolerant container with a lot of bugs.
    My op. system is win7 ultimate x64
    Have you got any idea?
    Thank You!
    Oct 2005
    666th portal
    you're talking about re-encoding the video. i.e. taking 2 fields and encoding them to create 1 frame out of it. anything that accepts the input, interlaces it into a correct frame and can output huffyuv will work. i use vegas pro on HDV 30p (psf) all the time.
    Jan 2012
    Budapest
    Hi!
    I would like to upload lossless transformed videos to youtube, because youtube automatic-deinterlacer worsened the quality of my PSF camcorder videos.
    Bye!
    Oct 2005
    666th portal
    does youtube accept lossless formats? i normally encode from HDV 30p to 1280x720p30 mp4 at a high bitrate. occasionally to 1080p30.
    Jan 2012
    Budapest
    Yes, it accept everything.... but it can't handle the PSF format correctly ((
