Replying to this thread of all members are welcome. But I can't find any perfect solution from my thread. Some members view is that either increasing bitrate or decreasing resolution u can get better quality picture. I saw different forum where different encoder release their movie within 700mb. So my question is that how they do it ? After searching through internet about my mission & reading different many articles about encoding with low bitrate & most probably I came to my solution. Using HD Insane Profile & most important thing using Low Bitrate Quantization Matrices I have encoded 3 movies upto 700MB from 4.37Gb With 720p resolution. Here is one of my result-
Results 31 to 37 of 37
Yeah I get it, jagabo. You don't agree. That's fine but I've gotten some good responses here in this thread and by PM, and from plenty of others as well. It's doubtful that anyone would have anything positive to say about everyone looking like a mannequin, etc.
I sometimes watch video withe even worse quality. But I would never make my own encodings at that low quality.
You missed the most important factor. Increase the quality of your source file. The higher quality the source, the more you can compress it while maintaining quality. Digital intermediates used to create a movie edit master are on the order of 4kx2k (4096×2160) at very high bit rates. Distribution copies range from 4k Digital Cinema to 1920x1080 Blu-Ray (~20-30 Mbps h.264) to multiple re-encoded TV broadcasts or cable. In the North America, tv/cable HD channels typically recode to 3 MPeg2 HD channels per 36 Mbps RF channel. ATSC broadcast of 1080i is ~12-17 Mbps average. DVB h.264 1080i is usually ~7-10 Mbps. By the time you capture off TV, the video has probably been re-encoded 3 times (4k to 1080i/720p, uplink or fiber distribution, TV station mux to ATSC/DVB).
Next most important for extreme compression is allocation of bit rate based on object motion, detail and exposure (e.g. blocks show first in dark areas and on diagonal edges). The more times a video has been re-encoded, the more corrupt the motion vectors. You can only squeeze the lemon so many times before you draw pulp. Encoding with constant quality setting allows the encoder to apply variable bit necessary for your desired quality setting. File size will vary by quality setting.
In other words, the film distributor with access to the 4k master will make a much higher quality 720p 800 Kbps copy than you can from a TV capture.Last edited by edDV; 23rd Feb 2012 at 14:40.
http://www.kiva.org/about -
DING DING DING! The most important component. If you are trying to compress something that you downloaded and has already been compressed, you are going to be disappointed. It's the GIGO principle at work!You missed the most important factor. Increase the quality of your source file. The higher quality the source, the more you can compress it while maintaining quality.
It's actually the opposite
At low bitrates, on lower parts of the compression curve, higher quality files with more detail , noise and/or grain, are more difficult to compress
This is the rationale for using denoisers or low bitrate matrices for high compression - they remove high frequency signals and smooth out details temporally - so you end up looking "plasticky" .
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 13:24 -
Improve video quality [HELP]
By v1rto in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2011, 09:46 -
How to improve the quality of the video
By kemo1000 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Apr 2011, 16:36 -
how to improve video quality?
By George2 in forum ProgrammingReplies: 1Last Post: 19th May 2009, 03:07 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
