Results 1 to 29 of 29
  1. I have got gogear vibe mp3, i want to watch video on mp3 but i cant convert beacuse i lost the cd so now i have WINFF and i need a code for WINFF
    MJPEG (.mp4): 128x128 pixels, 30 fps, 512 kbps
    See https://forum.videohelp.com/threads/331937-Need-to-convert-to-mp4-with-these-specificat...=1#post2136738
    And then make a custom preset in winff, see http://code.google.com/p/winff/wiki/HowToMakePresets
    Like in WinFF under File -> Edit Preset:
    Under Preset Command Line Parameters add
    -f mov -vf "scale=160:trunc(ow/a/2)*2" -c:v mjpeg -b:v 512k -r 25 -c:a adpcm_ima_wav -b:a 192k -ar 22050 -ac 2
    And under Output file
    mp4
    And Save
  3. Member bat999's Avatar
    Feb 2008
  4. i dont understand but i cant do it
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    What exactly do you don't understand? Are you using the winff edit preset?
  6. im just begining i dont how to start with winff
  7. when i write this code after i convert winff write that choose a edit export (something like).
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    I made a preset for you, download the zip file, extract the philipsgogearvibe.wff and in winff choose File->Import preset. You should then be able to select Philips gogear vibe.
  9. im using ur preset but winff dont let
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    You haven't selected it under "Konvertalas" and "Beallitasok". It should say Philips gogear vibe there.
  11. im solected now but
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    Try rename your files and folders so they don't use any special characters like
    C:\Users\Windows Vista\Desktop\dvd5\video.flv
  13. thanks for ur help
  14. i have got one question, how can i do full screen? beacuse video has 2 bands bottom and above and i want to watch in full screen
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    You must crop and resize it so it matches your display aspect ratio. No I don't know how to do it easily with ffmpeg or winff.
  16. what can i do now if the first was full screen in mp3 but now dont wanna ?
  17. i used resize but it is unuseful
  18. so that is
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    You should adjust the scale=160... value see http://ffmpeg.org/ffmpeg.html#scale .
    Or get a new portable media player with 16:9 display and better media file support....
  20. can u help with scale beacuse i dont know how to make, sorry but my english is really terrible
  21. I'm a MEGA Super Moderator Baldrick's Avatar
    It might be easier to use a separate tool to crop and resize to 1:1 aspect ratio(640x640,128x128,etc), like avidemux see tutorial: http://www.youtube.com/watch?v=KhqnwE9_dHI . Export the video and then use winff to convert it.
  22. Member
    May 2012
    nantes, France
    hi,
    my daughter has a philips gogear vibe mp4, and I try to get some videos for her.
    the specifications requested are similar to those below:
    General
    Complete name : ../../Formula 1.mp4
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 9.18 MiB
    Duration : 1mn 52s
    Overall bit rate : 687 Kbps
    Movie name : Formula 1 (160x128)
    Encoded date : UTC 2011-01-25 09:03:17
    Tagged date : UTC 2011-01-25 09:03:17
    Writing application : VirtualDubMod 1.6.0.0 SURROUND (build 2560/release)
    Video
    Format : JPEG
    Codec ID : jpeg
    Duration : 1mn 52s
    Bit rate mode : Variable
    Bit rate : 507 Kbps
    Width : 160 pixels
    Height : 128 pixels
    Display aspect ratio : 5:4
    Frame rate mode : Constant
    Frame rate : 24.000 fps
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.032
    Stream size : 6.78 MiB (74%)
    Language : English
    Audio
    Format : ADPCM
    Codec ID : 11
    Codec ID/Hint : Intel
    Duration : 1mn 51s
    Bit rate mode : Constant
    Bit rate : 176.4 Kbps
    Channel(s) : 2 channels
    Sampling rate : 22.05 KHz
    Stream size : 2.35 MiB (26%)
    Language : English
    I use winff and
    I got a preset for 128*128 video files, but our mp4 player reads 160*128 files.
    could someone explain to me what to do to change into the right format???
    thanks a lot (and I apologize for my uncorrect english!!)
    Thizerry
  23. Member
    May 2012
    nantes, France
    hello!
    rectifiaction: the winff preset I have, convert video files in quicktime 160*88 pixels 16/9 screen format.
    What I need is 160*128 pixels 4/3 format.
    could you help me?
    thanks tu you
    Thierry
  24. Member
    May 2012
    nantes, France
    Oh, I'm wrong again!!!
    what I need is 160*128 pixels, 5/4 format
  25. Member
    May 2012
    nantes, France
    anybody here??
  26. Member bat999's Avatar
    Feb 2008
    Which preset is this?
  27. Member
    May 2012
    nantes, France
    it 's Baldrick's preset for philips gogearvibe. he posted it on 12th febvruary 2012, but it is not based on the same specifications as my vibe.
    I need a preset for 160x128 with 5/4 ratio.
    This preset wprks correctly, but the videos on the vibe screen, appears with black parts, instead on being displayed on the whole screen.
    I think I just need a small change on one line command of the preset, but, even with investigations on forums ond manuals, I am not able to find what is to be changed...
    could you help ???
  28. Member bat999's Avatar
    Feb 2008
    it 's Baldrick's preset for philips gogearvibe...
    This preset wprks correctly...
    could you help ???
    Hi
    That preset makes the output video width 160 pixels.
    And it calculates the output video height to keep the same aspect ratio as the source video.
    I can't help.
  29. Member
    May 2012
    nantes, France
    ok, I understand.
    the size is even smaller than it could be, but nervermind,...it works, at least!
    yhanks for your answers
