What software can be used to take an image of a VCD so that it can be burned multiple times to make extra copies? I've been making images using Easy CD Creator, but the burned CDs come out in Joliet rather than as a VideoCD (so it doesn't play in standalone DVD/VCD players).
Thanks!
Don't use Adaptec or any of these other compliant only softwares.
Try this freebie.It burns anything compliant or not.
http://www.vcdhelp.com/vcdeasy.htm -
Copying multiple VCDs is the same as copying multiple copies of any other type of disc.
I suggest that you try using CloneCD or CDRWin to create an image of your disc and then burning it in DAO.
Regards.Michael Tam
w: Morsels of Evidence
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15 -
Multiple Copies of VOB files when copying dvds
By sativa36 in forum Authoring (DVD)Replies: 4Last Post: 17th Dec 2008, 17:29 -
Copying Multiple VIDEOS onto ONE DISK.
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2007, 19:30
