Results 1 to 11 of 11
    Jul 2008
    Is there any reason I should avoid putting a paper label on my DVD after I create it. I used to use Avery labels on CD-R's and wondering if this is not a good idea to use with DVDs. Just curious what your input is.
    Thanks,
    Rich
    Aug 2006
    Yes, there are reasons not to use adhesive labels on DVDs. The label can warp the disc, because paper and plastic don't expand at the same rate when heated. If the label is a bit off center, the disk becomes unbalanced. Either situation can cause playback problems. If the label starts to peel off during playback, it will wreck the drive.
    Jul 2008
    Thanks. I'll stick to the Sharpie then.
  4. Texan V Bot's Avatar
    Feb 2006
    I've regretted using adhesive labels, will never use them again.
    It Started In Texas
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Try a little effort.....
    In the media forum the SECOND sticky down....
    https://forum.videohelp.com/forums/28-Media
    Sticky labels can screwup the playback of your DVDR's
  6. PSCO2007
    May 2010
    Southern Ca.
    Thanks,
    Rich
    Every response is right on.
    When I started making dvds and used labls, they looked great.
    When I went to play them, I had 300 coasters.
    Since then, I have used the Epson r280
    It prints directly onto the disc and makes a dvd look professional.
  7. Texan V Bot's Avatar
    Feb 2006
    Thanks,
    Rich
    Not to change the thread, but which discs do you use? I looked into thermal printers, but they are expensive.
    It Started In Texas
  8. PSCO2007
    May 2010
    Southern Ca.
    Thanks,
    Rich
    I use Taiyo Yuden 8x -http://www.mediasupply.com/tydd5mwp8100.html
    and I buy the generic ink, which is a third of the price and just as good-http://www.rima.com/CTGY/EPNIK.html
  9. Texan V Bot's Avatar
    Feb 2006
    Psco2007, thanks for that.
    It Started In Texas
  10. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just an fyi I have that printer and in case other people don't know you have to buy PRINTABLE dvds and cds to use it for the printing function. As far as I know you can't put a regular dvd and print on it. I'm sure it is not a good idea to do that for the printer or the disc.
    An alternative is lightscribe discs. though I don't know if those have gone the way of hd-dvd by now or not. You can etch text and designs into them using a lightscribe burner but they are special discs and require a special burner. Plus the few I have made myself seem faint. At least the ones I've made. There might be newer models or different discs that are more vivid now.
    Then again like I said they could already be extinct for all I know.
  11. PSCO2007
    May 2010
    Southern Ca.
    Your'e welcome.
    BTW - the link I gave for the dvds points to Printable dvds , which of course you must use.
    You can also get this printer for under $100.00 - usually from Epson site - they are always running specials.
    Good luck.
    Paul
