My computer was super smooth before. Now it has been laggy for 2 days. Im thinking about if this could be the reason:
I tried to move some movies from my comp to USB device, the file size was about 10g, so i couldnt move it to the USB even though it had 30g free space. I found out it was because FAT32 format wont allow to transfer more than 4gb of files, so i turned it into NTFS. After that my computer has been laggy and been freezing and stuff. Can this be the reason? if it can, how can i turn it back to FAT32?
				Results 1 to 13 of 13
	Paragon partition manager 11 home - free edition ... will manage the task
 As for the lag dose it happen while the device is connected / disconnected
 Fat32 = max singular file size 4gb
 Backup all files before you convert ntfs to fat32.
 It can't. Can only go from FAT to NTFS.
	Hi PurkkaPoika,
 You can try a NTFS2FAT32 software to this.
 Check here: convert-ntfs-to-fat32
 Claudio
	My computer is Acer, and at my "my computer" folder, the acer folder is NTFS? is it supposed to be ntfs, or did i convert it accidently from fat32 to ntfs??
	Virus?
 You could run ComboFix and check it.
 - Disconnect the USB
 - Disable System Restore
 - Pause your antivirus and run Combofix.
 Link: how-to-use-combofix
 Claudio
	Start Task Manager (Alt + Ctrl + Del). Go to the Processes tab. If there's a button at the bottom that reads "Show process form all users" press it. Look to see if a process is hogging all your CPU time.
	I have 2 questions, do you have an antivirus on your computer and have you restarted it? I'm thinking you might have been infected while searching for an answer to why you couldn't copy that 10GB file; you'd have visited some unsavory site.
 A good antivirus that does real time scanning would stop drive-by infections most of the time. There are free ones, but they tend to really slow down computers. You can get Microsoft Security Essentials free, if you have WinXP SP3 and above; it seems to be easier on older hardware.
 As Jagabo mentions, you could have a process that's hung up (whether malicious or not). If that was caused by what you were doing and you never turn off your PC, this would be a good time to reboot it. If there's a virus, rebooting won't change that. Go here and run the version of Housecall that match your OS.
	Problem solved. Turned out that my windows hasnt updated any softwares for long time, because i dont have internet explorer installed in my comp. I updated every file, and ran virus scan one more time and now my pc runs perfectly!
 Thank you all for helping me! Really appreciate it! Bye.
  Laggy .MOV playback in VirtualdubBy a1ienz in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2010, 03:47
  Laggy Blu-ray/MKV playback. Too slow computer?By H2SO4JB in forum Newbie / General discussionsReplies: 44Last Post: 9th Aug 2010, 14:54
  Computer Doesn't boot up monitor when turned onBy kerrex_2006 in forum ComputerReplies: 10Last Post: 23rd Dec 2009, 12:20
  Conversion problem - Laggy (choppy) videoBy yaang in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 13:36
  MKV with srt = laggy (?)By therock003 in forum Software PlayingReplies: 5Last Post: 15th Jul 2008, 14:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
