Is there any utility or method out there to find out how many keyframes are in a given sample video?
Results 1 to 30 of 42
It depends on the video type, compression used
One way is to use ffmpeg/ffmbc or similar utilities like ffdshow's osd to print out a list of frametypes, then tally up the IDR frames
Note when dealing with h264, IDR frames are true keyframes (you can have "non keyframe" I-frames), this might not apply to other types of compression, where all I-frames are keyframes
See these discussions for ideas and examples
https://forum.videohelp.com/threads/342572-decoding-mpeg-video-into-frames-say-I-P-B-frames
http://forum.doom9.org/showthread.php?t=163553 -
Oh, I mean it seems as if a lack of IDR frames causes poor scanning throughout the video.
What are you trying to ask?
I didn't see any references to "scanning" in that article. Again what do you mean by "scanning" ? Seekpoints ?
Note context is important. Encoding for rtsp streaming is different than another scenario, maybe for PC files.
Open GOP will always be more efficient than closed. Having acceess to using non-IDR frames will always be more efficient than IDR frames only - which are are more expensive to encode.
Latency and seektime is reduced by all IDR frames (intra) - but that's the same reason why filesizes required are huge for a given "quality" over Long GOP. Similarly the longer the GOP interval, the slower the seek, but potentially more efficient compression (you fill up the GOP with less expensive P and B frames) -
Ok, I gotcha. So essentially more IDR frames = faster seek, larger file and less IDR frames = slower seek, smaller file.
So, I'd like to ask do you think you could let me know if this is a good idea?
1. import DV
2. compress to intraframe x.264 with --keyint1 and -bff ( or VirtualDub's smart filter??)
3. work with compressed intraframe x.264 to edit
4. export as xVid for final production, double pass
Does this sound like a good summary? -
In general , for a given type of compression and set of settings, yes!
(But there are many factors that can affect filesize for given level of quality, seektimes, CPU usage for decoding etc...)
What application are you using to edit?
1. import DV
h.264 is a very large spec (and x264 encoder supports many of the advanced features), but beware many programs do not support everything all the bells and whistles. I mentioned this in the other thread. So even if you convert it and it works fine a media player, it might not work in a standard NLE.
For example , in that link, Adobe flash at the time did not support open GOP - that's why you see the pixellated seek. If were to download the same video and play it locally with MPCHC (ffdshow libavcodec decoder) it would not be pixellated with the same seeking behaviour . Also some hardware devices treat non IDR "i" frames as IDR frames - so you get pixellated seeks. -
note that i say this in reference to some of the other posts you've answered/contributed to
how about i ask which NLE would work best with x.264? i'll work with whatever is best for this
And why xvid for final export ?? is final format for a device ? PC ? How do you intend to play it back ?
What about the other processing factors mentioned in the other thread? There can be night/day difference in quality between deinterlacers if that's what you're doing .
DV usually requires a lot of pre processing (in terms of denoising, chroma handling), this can make a huge difference final quality and filesizes (noise consumes enormous amounts of bitrate)
If you have the cash to drop on a NLE, I would just get a harddrive instead. Seriously. The amount of time and wasted with that proposed workflow for a DV source is seriously wrong. Time is money for most peoplehow about i ask which NLE would work best with x.264? i'll work with whatever is best for this
What kind of "editing" are you doing? just simple cuts ? or real editing with multiple transitions, layers, effects ? -
xVid because it's the most supported. the video is for pc, playback on pc.
i am deinterlacing, using virtualdub smart deinterlace. i'm willing to experiment with a few.
yeah i've been considering the hard drive. what NLE's would be best? -
Well maybe... but for devices (e.g. ipod/pad/phone, android etc...), h.264 is more supported these days
MPEG2 would probably be the most supported overall
This is a huge topic, and a lot of information can be found in various threads
"smart deinterlace" is very poor, even 5 years ago.
Have a look at an old comparison between some popular deinterlacers as the time
(right click, save as) . TGMC has been replaced by QTGMC these days
https://forum.videohelp.com/images/guides/p1934885/stockholma_0-520_q3_yadif_mvbobmod_t...mca4_tdtmm.avi
The more stable output means fewer difference between frames (instead of flickering and shimmer, which will "eat up" bitrate) - so your xvid output will require less bitrate as well (smaller filesizes and better quality)
Also , for a DV source, you should be bob-deinterlacing instead of throwing away half the fields (ie. 59.94i => 59.94p instead of 29.97p)
You can get x264 (I frame only) to work with premiere pro or sony vegas . Not sure about the consumer versions (premiere elements, vegas studio) . It also takes some extra work, interpreting the footage AR and field order (it not a commonly used format, as compared to DV-AVI, which you just pop in and edit right away, and AR and field order are automatically correct). But on a P4, I'm not sure you want to do this at all. NLE's add extra overhead, so even though it might play ok in a media player, it still might be sluggish in a NLE. DV-AVI will edit ok on a P4.
Ok, I got a QTGMC AVIsynth script and I'll load this up into virtualdub.
I really like DV, but I wonder if I can save the hassle here. It seems to me that the final output quality is ultimately going to be the same, if I edit in DV or h.264, it's ultimately going to end up in xVid. I may as well just drop the DV early, no? -
minus some generational recompression loss, which I can put up with and which I doubt will be very noticeable
Not using intra at low bitrates; most of the tremendous compression gains using x264 are from long GOP. There is not much point using x264 and intra when you have a DV file all ready to do
What were your expectations for the intermediate bitrate ?
Also, maybe your level of acceptable quality loss is different. You have to try it out and see if it's "good enough" for this case in your eyes -
ok, i'm gonna play around with these codecs and see what i come up with. long GOP at a high bitrate will still be more difficult to edit than x264 intra, no?
The point of long gop is so that you can use lower bitrates than intra, but it's less suitable for editing because of higher latency. I think you might have problems editing long gop h.264 on a P4. Its meant for distribution, final format goal, not editing
ie. Intra would require that you use high bitrates for a certain level of "quality". Intra requires high bitrates . Period. Any format. Yes you better compression with h264 intra over say MJPEG or MPEG2 intra, but it still going to be huge compared to a long GOP. Most intra intermediates are HIGHER than the original bitrate. SO many times the original filesize. So don't complain about DV size.
That's why I suggested non intra MPEG2 as an acceptable alternative. At ~12-15Mb/s (roughly 2-2.5x what DVD would use), it's decent quality at about a 1/2 the size of your DV starting point . It's also widely accepted and compatible in programs. Small sized , constant GOP (~15 frames) make it easier to edit as well. It lacks some of the features of h.264, so it makes it easier to edit (no CABAC, no inloop filtering) . You could get similar quality using all the features of long GOP x264 as that 12-15Mb/s MPEG2 but at about 6-9Mb/s, so much smaller but more difficult to edit - very likely unusable on a P4 (you'll be frustrated an pulling out your hair)Last edited by poisondeathray; 11th Feb 2012 at 16:12.
Ok, I do have a more powerful computer available to use as well, just the initial capture is done on a P4. I wonder how the theoretical part plays out here.
If DV is intra, wouldn't an intra compression reduce the size even more? How can it increase file size if you're further compressing?
with mpeg non intra, constant bitrate, 15 frames, would i be able to make cuts at less than 15 frames and maintain quality? or would cuts have to occur only every 15th frame?
argh... -
your comment in the other post was concise. i want reduced DV filesize for editing and storage. end of story. processing power is not a concern. any particular, dominant mpeg2 encoder you would recommend to give it a shot?
No. Filesize = bitrate x running time
So if you want , you can choose 1/10 the bitrate (thus 1/10 the size), but it will look like absolute garbage. In fact , even 1/2 the bitrate will pretty much look like garbage using any intra encoding (unless it's very simple complexity, like a blank wall)
But if you use intra compression, you need enormous amounts of bitrate to maintain a certain level of quality
Lossy compression vs lossless compression . Everything is compared to uncompressed. So if you use lossy compression the quality will always decrease, and if you want slightly less quality, but close, using intra, the filesize will actually be larger
If you're familiar with audio, and example would be mp3. If you re-encode mp3 over and over again , data gets thrown away each time, you minimize that loss by using higher bitrates. You can never get the same quality back. It's only downhill with lossy compression
If you have a smart rendering editor (e.g vegas can for mpeg2, but premiere cannot without 3rd party plugins), then only cuts within the GOP are re-encoded, everything else is passed thorough untouched. But you are incurring more loss by going to MPEG2 than keeping it DV in the first place. Also this smart rendering point is moot in your case, because you have already re-encoded it, and are going to re-encode it again to xvid. Smart rendering would only benenfit you if you were keeping MPEG2 (the same input format)with mpeg non intra, constant bitrate, 15 frames, would i be able to make cuts at less than 15 frames and maintain quality? or would cuts have to occur only every 15th frame?
Also if you use any global filters, like color correction, overlays those sorts of things, everything is re-rendered anyways -
If processing power isn't a concern, then go ahead and use h.264, long gop. That's the best compression bar none. You can customize various settings for faster decoding, or higher compression, maybe faster encoding is your goal etc...ie. you can customize x264 considerably , very highly configurable encoder
http://mewiki.project357.com/wiki/X264_Settings
At SD sizes, modern computers (quadcore or more) can handle it fine. It's only when you get to HD sizes, that h.264 becomes a pig and editing slow
If you still wanted to use MPEG2, you can use free programs: HCEnc (but it requires avisynth knowledge), ffmpeg (easier to batch process with command line, but MPEG2 quality is definitely worse than HCEnc) , or paid programs like CCE, Mainconcept Reference -
ok, i'll look into some long GOP h264 and see what i get.
just as an aside, i played around with x.264 --keyint 1 and i managed to reduce filesize to 20% of the DV with no insane loss of quality. it looks worse, but not terribly so. being intra and easier to edit, would this be a viable solution? -
i wanna beat this dead horse until i can get some meat from it, because whatever method i find to be best will be used for a large mass of video. and i don't want to go back and re-evaluate compression methods after i start
Regards,
Dmitry | SolveigMM | Smart Video Editing (H624/MPEG-2/...)
Listing keyframes
By Misterer in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2010, 10:36 -
Are variable keyframes possible?
By x2x3x2 in forum Video ConversionReplies: 15Last Post: 7th Aug 2010, 07:40 -
Are I-Frames the same as Keyframes?
By leopard in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2009, 07:23 -
changing keyframes in SUPER
By uglijimus in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 12:39 -
Keyframes and MPEG-2 editing
By ffooky in forum MacReplies: 8Last Post: 5th Feb 2009, 04:17
