Hi there.
I downloaded ffmpeg X to hardcode subtitles on my project, and it works perfectly for that. However on playback there is NO Sound!
I've tried different sound options but it still wont work. HELP!
Tomorrow is the last day I can upload my film to enter a film festival. This is the only software that I've tried in a week that actually hardcoded subtitles, and now no audio! Here's the info from my encoding.
Encoding started on Sat Feb 11 14:30:32 WAT 2012
FIXME:Hardenabling SSE and SSE2 without detection
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
CPU: Intel Pentium III Xeon Cascades (Family: 6, Stepping: 7)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
AVI: invalid audio stream ID: 0 - ignoring (nosound)
success: format: 0 data: 0x0 - 0x9a43bde
AVI file format detected.
AVI_NI: No audio stream found -> no sound.
VIDEO: [DX50] 720x400 24bpp 25.000 fps 1300.4 kbps (158.7 kbyte/s)
[V] filefmt:3 fourcc:0x30355844 size:720x400 fps:25.00 ftime:=0.0400
SUB: Detected subtitle file format: subviewer
SUB: Read 150 subtitles.
xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=720 h=400]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
VDec: vo config request - 720 x 400 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.80:1 - prescaling to correct movie aspect.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: XviD (720x400 fourcc=44495658 [XVID])
xvid: par=0/0 (vga11), displayed=720x400, sampled=720x400
xvid: CBR Rate Control -- bitrate=940kbit/s
1 duplicate frame(s)!
Writing header...
ODML: vprp aspect is 16384:9102.
Writing header...
Flushing video frames
Writing index...
Writing header...
Video stream: 940.608 kbit/s (117576 B/s) size: 105804295 bytes 899.880 secs 22497 frames
Encoding completed on Sat Feb 11 14:33:46 WAT 2012
Thank you in advance!
Thanks for your reply. Here it is.
Bit rate : 1 300 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.181
Stream size : 139 MiB (90%)
Writing library : DivX 2682
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 14mn 59s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 13.7 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Title : Audio -
From your first post:
FfmpegX looks like it's getting confused and trying to read the audio from the first stream (0) which is video, instead of the second stream (1).
In Ffmpegx, under the audio settings, what options are there for the 'audio track' drop down menu? If it's currently set to 0 but there's an option to set it to 1 - try that. -
Sound Problems again!
Trying to hardcode subtitles on an mpeg file. The subtitles come out great, but no sound! Please help!
Encoding started on Thu Mar 1 12:07:01 GMT 2012
CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 10)
success: format: 0 data: 0x0 - 0x29c6d000
MPEG-PS file format detected.
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
MPEG: No audio stream found -> no sound.
VIDEO: MPEG2 720x480 (aspect 1) 25.000 fps 6000.0 kbps (750.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:25.00 ftime:=0.0400
Too many video packets in the buffer: (4096 in 8292574 bytes).
SUB: Read 149 subtitles.
Opening video filter: [scale w=720 h=480]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
Movie-Aspect is undefined - no prescaling applied.
videocodec: XviD (720x480 fourcc=44495658 [XVID])
xvid: par=0/0 (vga11), displayed=720x480, sampled=720x480
xvid: CBR Rate Control -- bitrate=3121kbit/s
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Writing header...
ODML: vprp aspect is 16384:10922.
Writing header...
Writing header...
Writing index...
Writing header...
Video stream: 3111.741 kbit/s (388967 B/s) size: 349977544 bytes 899.760 secs 22494 frames
Encoding completed on Thu Mar 1 12:25:55 GMT 2012
Here's the Media info for the original file.
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 14mn 59s
Bit rate : 6 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Bits/(Pixel*Frame) : 0.694
Stream size : 638 MiB (95%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 14mn 59s
Bit rate : 160 Kbps
Stream size : 17.2 MiB (3%)
Thank you in advance. -
Sorry for the delay, I've been away for a few days.
I haven't actually used Ffmpegx - my last suggestion was a hunch, so I don't know what the cause of this new problem could be. Are there any audio settings in Ffmpegx that could be set incorrectly? Can you choose a different audio track or is the option disabled? What about the 'Encode audio' tick box.
No sound after encoding with TsMuxer
By Teddybaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2010, 13:31 -
Questions about sound encoding.
By Ramzinho in forum AudioReplies: 2Last Post: 14th Jul 2010, 06:17 -
Need Help Encoding: Surround Sound Goes Away
By antiwebbite in forum AudioReplies: 3Last Post: 9th Jun 2010, 18:48 -
Some questions, Re: 5.1 mixes, sound quality and encoding settings...
By takearushfan in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 03:13 -
H.264 Encoding - Sound Synching
By mabus in forum Newbie / General discussionsReplies: 5Last Post: 19th Nov 2009, 11:36
