Results 1 to 17 of 17
  1. Every time I record in 480p my capture card(component cables) seems to try to deinterlace it(or something?). When this happens, it results in flickering edges, kind of like aliasing. I'll provide a an example to show you what I;m talking about. Also, I've ran this through MeGUI and it says it's a progressive source. It might have something to do with my capture card converting a 480p signal to serial digital, which it shouldn't be doing but if I can fix this after capturing I'm good. I record with HUFFYUV as well.
    Pay attention to the edges of the video(ESPECIALLY the name above the head, it's flickering madness lol). If you need better examples I'll provide them.
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Whats capture card? Whats program use to capture?
    Strange because my 480p captures are 59.94 or 60 fps, never 29.97 or 30 fps.
    Claudio
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Also what is the source format? True 480p/60? Or a 30p camera format? Does the capture card support 30p?
    http://www.kiva.org/about
    Oct 2005
    666th portal
    doesn't even look like a capture problem to me. more like low-res game console output.
  5. Thanks for the replies, I use this capture card http://image.ec21.com/image/videoware/oimg_GC01203241_CA05625112/USB_2_0_HD_AV_Grabber_YPBPR.jpg
    I record with Virtualdub and the device supports 480p because I set my console to 480p(PS3) when playing. It's a weird problem and a weird capture device I know lol, I jut want to see if I can get this thing working properly before a new capture card (probably an HD PVR).
    EDIT: Is there anyway I can tell if it's being deinterlaced or not?
  6. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi MrBlack
    Its like ROXIO GAME CAPTURE (480p or 576p in 30/25 fps only).
    To make a great capture make this:
    - Record in 480i (Set your PS3 to 480i)
    - Use UT Video Codec or Lagarith or Huffyuv codec in YUY2 mode.
    - Use YADIF BOB deinterlaced (its will make a 60/50 fps file)
    Have a very nice file looks like real PS3.
    I make this on my RGC, the diference is abissal.
    Claudio
  7. Originally Posted by Cauptain View Post
    Hi MrBlack
    Claudio
    Ha yeah it is! It's actually a newer chipset than Roxio. Funny thing is, I've have done all of the above before(I've been doing that for the past year with my old capture card ). Yeah I don't like YADIF because it leaves too much color ghosting for me. I want to use QTGMC but it takes WAY too long. But still, it would be nice to play in 480p and record. I'm trying to eliminate the use of deinterlacing because upsclaling afterwards is a pain, whereas recording in 480p it upscales just fine.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you use mediainfo in text mode it should give you lots of info on the video.
  9. Originally Posted by aedipuss View Post
    Alright, here you go.
    Format : AVI
    File size : 1.67 GiB
    Duration : 3mn 14s
    Overall bit rate : 73.8 Mbps
    Video
    Format : Huffman
    Codec ID : HFYU
    Duration : 3mn 14s
    Bit rate : 72.2 Mbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : RGB
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 6.973
    Stream size : 1.64 GiB (98%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 3mn 14s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 35.6 MiB (2%)
    Interleave, duration : 500 ms (15.00 video frames)
  10. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    "YADIF ghosting problem" is fixed if capture in YUY2 mode.
    To record/play/preview in full 480p buy AVERTVHD, BMI or COLOSSUS.
    No problem upscale video after deinterlaced use SPLINE64 resize.
    480p@30 <<<<<<<<<<<<<<<<<<<<<<< 480i@480p via yadif bob mode.
    RGC 480i
    RGC 480P YADIF
    Claudio
  11. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Format : AVI
    Duration : 3mn 14s
    Video
    Format : Huffman
    Codec ID : HFYU
    Duration : 3mn 14s
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Color space : RGB
    Bit depth : 8 bits
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 14s
    Bit depth : 16 bits
    Use YUY2 only.
    Claudio
  12. Originally Posted by Cauptain View Post
    Format : AVI
    Duration : 3mn 14s
    Video
    Format : Huffman
    Codec ID : HFYU
    Duration : 3mn 14s
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Color space : RGB
    Bit depth : 8 bits
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 14s
    Bit depth : 16 bits
    Use YUY2 only.
    Claudio
    I have it set to YUY2 when I capture, have no clue why it says that.
    @Cauptain Alright I'll try Spline64.
  13. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Its normal in HUFFYUV codec. no problem.
    But try UT video codec. Its give real YUY2 file record, look down:
    General
    Complete name : D:\CAPTURAS\VIRTUALDUB\5556.avi
    Format : AVI
    File size : 65.5 MiB
    Duration : 12s 867ms
    Overall bit rate : 42.7 Mbps
    Video
    Format : YUV
    Codec ID : ULY2
    Codec ID/Info : Ut Video Lossless Codec
    Codec ID/Hint : Ut Video
    Bit rate : 41.2 Mbps
    Width : 720 pixels
    Height : 480 pixels
    Frame rate : 30.000 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Compression mode : Lossless
    Bits/(Pixel*Frame) : 3.973
    Stream size : 63.2 MiB (96%)
    Months ago I make a guide to make SD in HD file but multiupload is down. I will reup this and post here.
    Claudio
  14. Originally Posted by Cauptain View Post
    General
    Format : AVI
    Video
    Format : YUV
    Codec ID : ULY2
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Color space : YUV
    Claudio
    Okay thanks for your help man.
  15. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Take here: Make Videos SD to HD
    Claudio
  16. Originally Posted by Cauptain View Post
    Claudio
    Thank you VERY much, I saw your video on youtube and the quality is amazing man.
  17. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    You are welcome MrBlack.
    Claudio
