Does any kind of simple gadget exist that would allow me to start and stop recording two cameras simultaneously? It doesn't have to be exactly at the same time, just so that the number of scenes/files would be the same in the end..
Depends on the cams
If they've a LANC, you could buy 2 remotes controls...or perhaps split them with a Y connector controlling both with one remote -
I'm not familiar with LANC, but I just did a quick google search on my two cameras and saw that they both support LANC so at least this is a starting point for me. I will investigate further, thanks! =)
Would something like this work?
http://www.bhphotovideo.com/c/product/739959-REG/Camtrol_CAMR2100_Camtroller_Remote.html
For $200 for a couple of those, I think it would save a lot of hassle trying to figure out what's what in post.
Another one too:
http://www.bhphotovideo.com/c/product/568482-REG/CobraCrane_5041_215392_LNC_50_Remote_...ontroller.html -
sure...anything that supports lanc
here's another
http://www.bhphotovideo.com/c/product/732729-REG/Vivitar_VIV_RC_800_8_Button_Remote_Control.html
see if your cams came with a wireless remote
check newegg, etc.
Playing Videos in a certain order with only certain start and stop times?
By spudz72 in forum Software PlayingReplies: 0Last Post: 5th Aug 2010, 01:56 -
Videoplayer with start/stop and overlay drawing function
By videoamateure in forum EditingReplies: 6Last Post: 14th May 2009, 19:21 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
DVD-R recordings stop and start during playback
By Walsallian in forum DVD & Blu-ray RecordersReplies: 24Last Post: 11th May 2007, 07:14
