Hi
I joined to ask a question troubling me for 2 days now. I usually don't do any advanced editing beyond simple tested conversions, but now needed some more
I have a presentation which I managed to unpack in 1280x720 PNG files, then "mogrify" those PNGs to correct colorspace
Also have mp3 audio source of this presentation, which I cut with made cue sheet
Now I tried to make something useful, basically by this command (simplified a bit to avoid confusion):
FPS (1/$X) is calculated inline 1/`mp3info -p "%S" $1` which outputs reciprocal mp3 length in seconds and above one-liner is processing all files in one quick passCode:mencoder mf://01.png -mf w=1280:h=720:fps=1/$X:type=png -audiofile 01.mp3 -ovc lavc -lavcopts vcodec=mpeg4:mbd=2:trell -oac copy out.avi
Then I join created AVI files:
And result is perfectCode:mencoder -oac copy -ovc copy -idx -o output.avi *.aviVery small AVI file (because it basically has couple of frames and it size is made just by audio files) it can easily be navigated to previous/next slide and quality is great in any player I tested.
Problem is that I can't upload this file as AVI so I need to convert it to M4V or FLV.
For example, I used x264 video codec though mencoder (tried ffmpeg too), but simply I cant join intermediate (M4V) files to make useful result file.
I used mp4box which does not complain about different FPS and joins them in valid M4V, but couldn't find player to play result file
Then I used same video codec as in AVI in FLV container, but it's same as I can join them to usable result FLV file
Does someone faced this problem? Is there a hope to do it this way - make reasonable MP4/FLV slide-show with uneven split points, without bloating file with 30 FPS?
Thanks for reading
Results 1 to 1 of 1
KMplayer problem: cannot play the .flv and .mp4 files
By hithit168 in forum Software PlayingReplies: 3Last Post: 13th Jul 2011, 04:01 -
Joining mp4 files (same fps and codecs but slightly different resolutions)
By AshleyQuick in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 22:28 -
editing mp4/flv files from youtube in virtualDub
By tolland in forum EditingReplies: 2Last Post: 16th Nov 2009, 17:50 -
Should I convert .flv files to .avi or .mp4?
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 1st Dec 2008, 14:51
