Hi guys just got my blackmagic intensity pro trying to record on my xbox 360 with 1080i but when i seem to record on my intensity pro the video flickers any ideas?
like that
http://www.youtube.com/watch?v=MSX13QgpjiU
Results 1 to 11 of 11
Most likely the hard disk can't keep up so drops frames. Are you using the MJPEG codec to lower bit rate? If so, increase compression. Too much compression may cause your CPU to peg. This too causes dropped frames.
Uncompressed 1080i capture requires 2-3 drives in RAID zero.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
i havent even started recording
i just flickers when i get everything plugged in
is there anything i can do to stop this? -
Blackmagic Intensity Pro Help.
By MoonVid in forum Capturing and VCRReplies: 1Last Post: 4th Nov 2011, 16:10 -
Blackmagic Intensity Pro.
By liamb96 in forum Capturing and VCRReplies: 8Last Post: 18th Oct 2010, 16:20 -
Blackmagic Intensity Pro 3.5.1
By Lynas in forum Capturing and VCRReplies: 24Last Post: 10th May 2010, 13:28 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
BlackMagic Intensity Pro
By Richintx in forum Capturing and VCRReplies: 0Last Post: 23rd Jan 2010, 09:43
