Have been using AutoGK successfully for a long time now but got problem yesterday when I tried to convert a ripped (VOB files with an IFO file) DVD to avi format and the problem is a described in the title...the video is playing in what could best be described as slow motion but the sound plays normally.
Never seen or had this problem before, anyone know what could be causing it and if there maybe is some setting in AutoGK I could change to help fix the problem? I also tried playing the VOB files directly and then all was fine so my conclusion is the VOB files are OK but it's rather something when converting them to avi using AutoGK that doesn't work.
Thanks in advance for any input!
//Richard
This is what I get checking the IFO file
General
Complete name : C:\Users\Richard\Desktop\Test\VTS_01_0.IFO
Format : DVD Video
Format profile : Program
File size : 72.0 KiB
Duration : 1h 53mn
Overall bit rate : 86 bps
Video
Format : MPEG Video
Format version : Version 2
Duration : 1h 53mn
Bit rate mode : Variable
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Compression mode : Lossy
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 53mn
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Language : English
Text
Format : RLE
Format/Info : Run-length encoding
Bit depth : 2 bits
Language : Swedish
Menu
Duration : 1h 53mn
00:00:00.000 : Chapter 1
00:08:05.320 : Chapter 2
00:20:05.040 : Chapter 3
00:27:30.160 : Chapter 4
00:36:55.520 : Chapter 5
00:49:27.040 : Chapter 6
01:00:05.360 : Chapter 7
01:08:06.120 : Chapter 8
01:17:52.640 : Chapter 9
01:24:30.720 : Chapter 10
01:36:44.120 : Chapter 11
01:43:35.400 : Chapter 12
01:47:44.480 : Chapter 13
01:53:14.960 : Chapter 14
List (Audio) : 0
List (Subtitles 4/3) : 0
List (Subtitles Wide) : 12
List (Subtitles Letterbox) : 12
List (Subtitles Pan&Scan) : 0
And this is what I get checking the first VOB file
General
Complete name : C:\Users\Richard\Desktop\Test\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 33mn 3s
Overall bit rate : 4 331 Kbps
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Duration : 33mn 3s
Bit rate : 3 861 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.372
Stream size : 913 MiB (89%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Muxing mode : DVD-Video
Duration : 33mn 3s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 90.8 MiB (9%)
Text
ID : 189 (0xBD)-44 (0x2C)
Format : RLE
Menu -
Tried Handbrake and that gives me both normal video and audio but I can't get the subtitles to display although I have chosen the preferred subtitle track and added it and a second thing...is it possible to have the output to an avi file rather than a m4v file? I'm using WMP in Win7 to stream to a Samsung TV and this works great with AVI files...not sure if it would work with a m4v file (haven't tried yet since I still haven't got the subtitles to display)
//Richard
Super slow motion video experimentation
By snafubaby in forum Video ConversionReplies: 3Last Post: 27th Mar 2012, 10:45 -
MP4Cam2AVI converts my video to slow motion
By sozuki in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 17:31 -
Convert MKV >> AVI : video is slow...
By condorman in forum MacReplies: 3Last Post: 22nd Aug 2009, 05:02 -
Problem ripping a movie to avi with AutoGK, fast motion audio/video
By Mr. SoAndSo in forum DVD RippingReplies: 1Last Post: 7th Oct 2008, 11:57 -
convert DVD segment to slow-motion video
By jackieO in forum Video ConversionReplies: 2Last Post: 7th Oct 2007, 15:36
