I tried both 1.16.5 and 1.17.0 and I can't seem to keep the dts-hd track.
I bring in the file (test purposes MKV track). I select Core/and leave it at DTS Master and the profile is set as Copy Stream but after it encodes it only shows DTS not DTS (MA/Core) like it does after I put it thru handbrake.
Am I missing something?
try this staxrip. i like tyhis program it is easy to add 2 audio tracks and filters.however u can do it with ripbot too.you need a new tool mkvtoolnix or tsmuxer or mkvmerge.convert main movie to mkv and then use mkvmerge to add new audio which is dts-hd.u must be carefull about file size.well if you use 8,5 gb dvd first get lost dtshd audio filesize 8,5 gb -1gb and getr target your video file size at 7gb on ripbot.this means u will make 2 pass cons.in staxrip u can select audio file at temp folder it creats and choose "just mux" so it will not any conversation on audio.
Strange subtitle issue w/Ripbot
By Rod419 in forum Blu-ray RippingReplies: 2Last Post: 28th Nov 2011, 05:17 -
Ripbot Issue
By Yeomans in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2010, 07:28 -
TS to MKV using RipBot video quality issue
By dracusorr in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2010, 23:34 -
Ripbot 1.15.0 issue
By ctaylor6766 in forum Blu-ray RippingReplies: 0Last Post: 10th Apr 2010, 12:42 -
How to cut vob file by keeping DTS track
By sureshforum in forum EditingReplies: 2Last Post: 1st Feb 2008, 09:13
