today i hooked up my AverMedia Avertv. i installed the drivers that was on the disc and i started up the program. i went to capture mode and my avertv is flashing blue red orange lights. and its not capturing the screen. all i see is black. any help??
It is hard to be helpful without more information...
1. What capture software are you using? Is it the one AVerMedia provided or something else?
2. Did you check to be sure the computer you are using for capture meets the capture software's hardware requirements?
3. What game system have you had these problems with and are you using a component cable or HDMI to connect it to the Avertv HD DVR?
4. The analog and HDMI ports on the HD DVR look very similar. Are you using the correct one?
5. What video system do you use in your country (NTSC or PAL) and does the game you had problems with use the same video system? -
Welcome streetkilln
In this order
1: install drivers and software first
2: reboot the pc
3: now connect the device.
If device is card, at 2 shut down pc, remove systems power cord and install card ... system will detect an install device drivers ... reboot once more to complete.
Now try capturing.
Need Original Drivers for Avermedia AverTV HD DVR (c027)
By Cam94Z28 in forum Capturing and VCRReplies: 189Last Post: 30th May 2023, 20:42 -
Avermedia avertv hd-dvr problem
By ABUELLO in forum DVB / IPTVReplies: 9Last Post: 28th Feb 2012, 23:21 -
Problem with the AVerTV HD DVR.. Please Hellllppppp!!
By puroespirito in forum Capturing and VCRReplies: 0Last Post: 1st Sep 2011, 08:58 -
AVerMedia AVerTV HD DVR chips? (photos)
By Brad in forum Capturing and VCRReplies: 3Last Post: 31st Oct 2010, 14:13 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 13:47
