Default is set to 40, but would it improve quality putting it to 100 or would it make it worse? Or is it not even worth turning on? Cheers guys
Depends on the source. 99.9% of the time it's fine at default. Not worth turning it off
Try it and find out. Impossible to answer in generic terms. The question is too vague. It depends on the source, the encoding settings, situation, bitrate curve for that particular source.
If you are on the lower end of the curve, it might place more IDR frames, lowering average quality where it could have placed a P frame. But on the other hand it might improve quality in other cases where you have sufficient bitrate. Other cases it might not affect at all, or imperceptible change in quality, only metrics
Auto-chapter (on scene change) w/ eg. Matroska?
By Gew in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2010, 10:46 -
x264 artifacts on dark scene
By kartul in forum Video ConversionReplies: 18Last Post: 3rd Nov 2010, 16:14 -
What is the smallest amount of change in color that the eye can detect ?
By Movie-Maker in forum Newbie / General discussionsReplies: 8Last Post: 6th Dec 2008, 10:41 -
Scene change detection
By Lele in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 02:13 -
Detect scene changes in Avisynth?
By AlanHK in forum EditingReplies: 0Last Post: 12th Aug 2007, 06:12
