  1. Hello I have a 6 channel recording of a movie scene from Robocop, I would like to isolate ED209 voice alone and silence the screaming and other voices.
    WAV:
    http://www.mediafire.com/?048j0fx0so73339
    AC3:
    http://www.mediafire.com/?xh2i017mzfaqfpl
    The file seems corrupt. Unexpected end of file.
    But I would try audacity and goldwave.
    edit: Something wrong with mediafire. The file worked when I downloaded the second time.
  3. I tried audacity but couldn't find a way to separate the voice because it's on the same track as the other noise.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    In Audacity the robot voice is in the 2nd channel, also the gunfire. Humans are in the other channels.
    Dec 2005
    Canada
    WAV:
    AC3:
    Using Audacity, I hear the Robot and the screaming bystanders in the second channel - I don't see how they can be removed.
  6. Originally Posted by sambat View Post
    I noticed this, that's why I'm asking on this forum. I was wondering if there is a way to filter the robot voice in a frequency range.
  7. Banned
    Freedonia
    No.
    Eventually such software may exist as audio processing has already become able to do things that were considered impossible or almost impossible back in the 1990s, but at this time you cannot do what you want. You can set a frequency filter but it's still going to let some of the background noise through.
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Like Baldrick said, use audio software that supports 5.1., basterd. Like Audacity! That way all the channels will be preserved. If you convert to anything else, you're hosed, basterd!
    Here's the voice only file: https://forum.videohelp.com/attachments/10883-1328984007/RoboCop.mp3
    OK, Basterd? Hahaha, love that handle.
