How to make VirtualDub recognize FLAC?
I mean when I select
"Audio"->"Browse for audio..."
I can select some other containers (wav,mp3,ac3...), but not FLAC.
Is there some kind of plugin?![]()
WAV is a container, whereas MP3 and AC3 are compression methods.
Yes, there exists a FLAC ACM decoder, however I don't know how well it works.
There is no way (at this moment) to open FLAC audio (from external .flac file) in VirtualDub.
Except of course, imports through Avisynth script or DirectShow import driver - but that way you get uncompressed audio in VirtualDub.
No.
BTW
It seems that you are using old VirtualDub - probably VirtualDub-MPEG2 (which is discontinued - superceded by input plugins).
When I checked... encoding somehow works, but decoding not well.
Also... this does not provide ability to open .flac file.VideoAudio.pl - Serwis o technologii wideo & audio -
Now you can import it.
First remux the flac file to mkv then import with the Matroska input plugin.Codec Toolbox RS (A tool to read/change merit of codecs and many other things)
Flac archive
By jebinio in forum AudioReplies: 3Last Post: 3rd Apr 2011, 18:56 -
Converting FLAC
By mark91 in forum AudioReplies: 6Last Post: 11th Jun 2010, 17:42 -
ALAC vs FLAC?
By Nitro89 in forum AudioReplies: 10Last Post: 27th Oct 2009, 05:34 -
what is flac file?
By aruwin in forum AudioReplies: 11Last Post: 19th Nov 2007, 07:33 -
FLAC, should i use this?
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2007, 09:17
