If you go to a website and it has a streaming video file you want, I discovered recently if there is a picture you click on that takes you to the video to be played, that if you are using Firefox, you can right click on the picture and chose "copy link location" and paste that into Freemake Video Downloader and it will find the file and start downloading it. I like this method because you don't have to start playing it on the website, which would slow down your download rate.
I also noticed if you are concerned about how many gigabytes you are using to download the files, it is best to put in a just a few files to download at a time, that way it gets quite close to how much you should be using. I used to load in as many as 20 or 30 files to download and walk a way and come back later after a number of hours. What I found out is that it will download the files, but when you check your gigabyte consumption log at your ISP, it can be twice as much as what the files add up to in gigabytes.
I think the program is pretty good at what it can do.
Results 1 to 1 of 1
I can't locate a video downloader that will...
By Daniel_B. in forum Newbie / General discussionsReplies: 17Last Post: 25th Jun 2015, 03:03 -
Freemake video encoder video gets green screen
By flashcabaja64 in forum Video ConversionReplies: 7Last Post: 20th Mar 2012, 21:23 -
Freemake Video Convertor. What a tease.
By hellfire45 in forum Video ConversionReplies: 8Last Post: 28th Aug 2011, 19:58 -
Ant Video Downloader
By devilcoelhodog in forum Video Streaming DownloadingReplies: 2Last Post: 26th Nov 2010, 11:25 -
Having problems converting FLV to mpeg with Freemake video downloader
By sarbot in forum Video ConversionReplies: 10Last Post: 11th Sep 2010, 22:41
