Hello...new to the forum but not to video editing and such but I have a slight problem here. I have several clips captured by my new Colossus capture card and I would like to burn these to Blu-ray video disc. When I add these files to tsMuxer and remux for Blu-ray the resulting Blu-ray folder isn't playable using the software I use for viewing Blu-ray material. The software is TotalMedia Theatre. Also when using tsMuxer there was an error: Unsupported media type 15 for AVCHD/Blu-ray muxing. Also it states tsMuxer finished with error code -2. I can however click on the file in the Stream folder and it will play as a file but it seems that frames are missing here and there making the audio jumpy and the audio sounding like it is skipping.
I have also tried multiAVCHD 4.1 to do this. When I add the file or files to multiAVCHD, in the lower pane the file shows up and it is highlighted in red. When I place my mouse over this red highlighted file it says that the width, height and codec is not compliamnt.
Also in multiAVCHD it says click the file to open extended properties. I do this and the width, height and fps is left blank. I fill in this information and click OK and get an error which states: "DownloadInFile: fWrite: (RT) The Handle is invalid - Line 132." What does this error mean?
Another thing is that I edited out the comercials from the captured clips using Videoredo. That process seamed to work fast and ok with no quality loss as it should. I sure hope someone can help me through this. Thanks!
Here is the information retrieved by MediaInfo for the clips.
Complete name : M:\_DATA\Edited\CCC.S01E05 - XXX.ts
Format : MPEG-TS
File size : 2.36 GiB
Duration : 20mn 49s
Overall bit rate : 16.2 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 27
Duration : 20mn 49s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 20mn 49s
Bit rate mode : Variable / Variable / Variable
Minimum bit rate : 179 Kbps / 179 Kbps
Maximum bit rate : 196 Kbps / 196 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Maybe https://forum.videohelp.com/threads/340504-Issues-authoring-Blu-ray-disc-from-captured-...=1#post2118671
You can also try avchdcoder instead of multiavchd.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
Problems authoring Blu-Ray from HD Camcorder files
By Arnold_Layne in forum Authoring (Blu-ray)Replies: 3Last Post: 30th Jun 2011, 12:35 -
Authoring Blu-Ray
By whoisquilty in forum MacReplies: 3Last Post: 13th Aug 2010, 11:57 -
Play files without authoring on my blu-ray player Sony BDP-S360
By vandaLo in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th May 2010, 00:50 -
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 20:52
