Hi all,
I recently discovered an AVS script that uses Mvtools2 to create slow-motion. After several tests I gotta say I am most impressed with the results.
My workflow was fairly simple, I simply Frameserve out of Sony Vegas and open the script through Vdub.
My problem is that now I would like to apply this slow-motion technique to all the clips in my current project before editing it. This is not hte first time I needed to correct and/or adjusts clips, export them and import them again in order to be able to edit with greater ease. In this kind of situation I would simply export all those clips in a 50 mbps MXF format. As far as I can tell this is a lossless a workflow as it can get.
For my current project it seems I won't e able to do the same since I can't frameserve to Vdub and encode it in MXF.
What would you recommend for a lossless workflow in this situation?
Thanks,
Phil
I would encode (apply the mvtools2 script) to a lossless intermediate e.g. ut video codec, lagarith, huffyuv, etc... then import those AVI's into vegas . Filesizes will be large, so make sure you have extra HDD space
You can frameserve in without large intermediate files (e.g. AVFS), but there is extra overhead, and it's slower, more sluggish to edit, especially if you are applying (slowish) avisynth filters in realtime
BTW, MXF is just a wrapper - it says nothing about the video. It might be DNxHD, it might be DVCProHD, it might be MPEG2 etc... -
MXF is a container. Common implemtations are Sony XDCAM-EX (MPeg2) or Panasonic P2 DVCProHD or DV25/DV50 in MXF wrapper. Also fully uncompressed 4224/4444.
http://www.kiva.org/about -
50Mb/s? - Not lossless as per your original request if lagarith gave you 185Mb/s on that sample
Even something "visually lossless" like cineform or dnxhd will only be slightly smaller than lagarith, maybe ~100Mb/s
Maybe I-frame MPEG2 would be ok, but at 50Mb/s it's going to have significant artifacting, you need >150 -200Mb/s for HD
Long GOP MPEG2 is ok around 100Mb/s for HD for a lossy intermediate
Long GOP AVC is ok around 50Mb/s for lossy intermediate, but it's difficult/sluggish to edit . I-frame is much smoother to edit but you need higher bitrates for equivalent quality
I guess it depends what is acceptable quality loss for you. Or you can try avfs - no large intermediate files at all
try to render file with HuffYuv video format on Sony Vegas, please help!!!
By byair74 in forum EditingReplies: 0Last Post: 15th Feb 2012, 03:28 -
Best format and settings to render for youtube in sony vegas 7
By fuzzblaster in forum Video ConversionReplies: 4Last Post: 25th Dec 2010, 09:35 -
Which format is best to capture and edit from DVD's in Sony Vegas
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 07:38 -
What is the best format to convert AVCHD into before editing in Sony Vegas
By TigerSoul in forum Video ConversionReplies: 2Last Post: 10th Mar 2010, 16:55 -
Exporting from Final Cut Express to P2 native (MXF?) format?
By Cyrax9 in forum MacReplies: 2Last Post: 1st Jun 2009, 14:55
