Dear all,
Attached file here
I've managed to extract a sup file using DVDSubEdit to srt. However it ends up that the srt has an progressive sync issue. I've tried to use subsedit.com to fix but to no avail as the site is buggy and the progressive sync issue remains. I guess it was the DVDSubEdit that caused the progressive sync issue because the audio and the video were in sync.
I've tried another method, that is to use Vobedit to demux the subpicture stream and then opening the .sup file with Subtitle Creator but it doesn't work. The error goes something like "Object reference not set to an instance of an object."
Then I've tried using the BDSuptosub and there was also an error when opening. The error was "ERROR: Unexpected command 0 at index 0x00000012"
Tried using SupRip as well, the error was
unrecognized block code
Void LoadHddvdSup(System.IO.FileStream)
at SupRip.SubtitleFile.LoadHddvdSup(FileStream fs)
at SupRip.SubtitleFile.LoadFromSup(String supfile)
at SupRip.MainForm.LoadSubtitleFile(String fileName)
I am really desperate to know why the sup file didn't work with most programs. But if only I could find a good way to fix the progressive sync issue with the srt file without having to manually re-time every subtitle, that would be great enough.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
BDSupToSub doesn't support DVD SUP files, only Blu-ray ones. SupRip also doesn't support DVD SUP files.
I usually do an instant conversion from SUP to VobSub (IDX/SUB) in SubtitleCreator followed by an OCR using SubRip. I have no idea why your timings got progressively off as I've used DVDSubEdit before with no problem. It screws up the OCR a little bit sometimes, though. -
Hello
Thank you for your quick reply. I managed to solve the issue with the progressive sync. What I did was open the SRT file in Subtitle Creator and Synchronize --> Convert frame rate, from 30 fps to 29.97 fps and the srt file came out perfectly in sync. I was not sure why DVDSubEdit read the sup file at 30fps when the frame rate was 29.97 to begin with. I picked 30 and 29.97 out of randomness, but I seem to have hit the right conversion ratio. I'm okay with the screwed up OCR because OCR is never 100% correct to begin with, given how l and I look the same in certain fonts. What I did was manually corrected the subtitles
I must thank this thread for solving the issue, didn't noticed it before: https://forum.videohelp.com/threads/287173-AVI-and-SRT-subtitles-increasingly-out-of-sync
In other words, I must thank you for your advice in another threadLast edited by sooojaded; 7th Feb 2012 at 12:01.
Oh, so it was a dropframe timing (29.97fps) versus no-dropframe (30fps) issue. I came across that same problem myself the other day. It happens, but rarely, in my experience. If the subs start off OK and wind up a few seconds off by the end (about 7 seconds for a 2 hour movie), that's almost always the issue. PAL/NTSC problems result in subs off by several minutes by the end.
For future reference, first make sure you have the latest DVDSubEdit version (1.52). Then, if it happens again, go File->Preferences->General Settings, and check the 'Use drop-frame time code' box and that should fix it.
AVI and SRT subtitles increasingly out of sync
By fiiido in forum SubtitleReplies: 27Last Post: 31st Jul 2012, 09:53 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
srt subtitles files
By robotica71 in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2009, 10:16 -
can't get srt subtitles to show up
By fmiller4 in forum ffmpegX general discussionReplies: 5Last Post: 19th Jan 2009, 12:16
