is there a way to use the lame MP3 with virtualdub 64bit?
i try to do this:
i try also to do the same using the system32 folder instead of SysWOW64 but i can only use the lame MP3 on the 32bit version of virtualdub1. Extract it to for example c:\lame
2. Run cmd with admin rights (ctrl+shift+return)
3. cd %windir%\SysWOW64
4. rundll32 setupapi.dll,InstallHinfSection DefaultInstall 0 C:\lame\LameACM.inf
You need the 64 bit version with a 64 bit program. Get it here:
https://www.videohelp.com/download/lame3.99.4-20120130-64.zip -
It just includes the 32bit version. I haven't seen any 64bit version at http://www.rarewares.org/mp3-lame-dshow-acm.php
There's no benefit to running 64 bit VirtualDub. You might as well use the 32 bit version because there's far more support in 3rd party filters and codecs.
i tried everything, but only this worked:
https://forum.videohelp.com/threads/271712-Lame-MP3-Encoder-on-Vista-x64?p=2016711&view...=1#post2016711
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 13:55 -
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 17:44 -
I can't change AVC codec to ffdshow under win7(64bit)
By skinney6 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2012, 12:08 -
I can't get multiAVCHD to install running win7 64bit
By Onceler2 in forum Authoring (Blu-ray)Replies: 0Last Post: 17th Sep 2011, 21:29 -
Avi Gain and Win7 64bit problem
By Silsur in forum AudioReplies: 2Last Post: 5th Nov 2010, 06:15
