Results 1 to 9 of 9
  1. Member wolfdogg's Avatar
    May 2011
    Portland, OR, USA
    i have an .mkv file that consists of h264, and ac3 audio. standard isnt it? well, i want to get it to an avi container, so i can run it though nero vision to get it to dvd. seems the easiest high quality method for me.
    i am having a problem with sync where first i ran the file through MKVExtractGUI2 to demux,
    then i converted the .h264 video file to h264.avi file with avc2avi_r594+gui1.2,
    then i tried to mux the video in its new .avi container with the demuxed .ac3 audio with AVI-Mux_GUI-1.17.8 expecting an in sync complete .avi output. I assumed that this would be a nice complete .avi ready to run therough nero vision. I also assume what i did so far was losless, so seems a great way to do it.
    Th problem is the .avi file is way out of sync. Where am i running into the sync problem? is there a better way to get a .mkv to a VIDEO_TS folder full of .VOB's ready for burning?
    it appears that the specs of the original file is
    Format : Matroska
    File size : 2.47 GiB
    Duration : 2h 13mn
    Overall bit rate : 2 642 Kbps
    Video
    Format : AVC
    Bit rate : 2 000 Kbps
    Display aspect ratio : 1280 x 720 (16:9)
    Frame rate : 23.976 fps
    Writing library : x264 core 112
    Encoding settings : cabac=1 / ref=7 / deblock=1:-1:-1 / me=umh / subme=10 / me_range=64 / chroma_me=1 / trellis=2 /
    8x8dct=1 / bframes=9 / b_pyramid=2 / b_adapt=2 / weightp=2 / rc_lookahead=100 / rc=2pass / mbtree=1 / bitrate=2000 /
    i feel stoopid, upon inspection, i suspected it might have been the converion of the h264 video into an avi container, so i ran the AVC2AVI program again to have a look at its limited settings which i ddint remember too many, and i stumbled right on the one setting that says FPS, and it was set on 25.0, and i assume my video is NTSC. so im guessing a simple adjustment of 23.976 there will get me back on track.
    Use avstodvd to convert your mkv directly to dvd instead.
    If you still want to use nerovision to make custom menus you could output as mpeg2 in avstodvd(choose output->muxed mpeg2 file) and then use the mpg nerovision.
  3. Member wolfdogg's Avatar
    May 2011
    Portland, OR, USA
    ok, sounds good, thanks. im trying that now too. looks like its what i need.
  4. Member wolfdogg's Avatar
    May 2011
    Portland, OR, USA
    avstodvd, that program works great. made a clean disk.
    before that, with my prior method, i was noticing that when i ran the video through AVC2AVI , it wouldnt set the frame rate properly to 23.976, although i set it to that, it was coming out at 23.975 everytime. so in order to complete the first method, i had to run that video through virtualdub to reset the proper frame rate, and sure enough, the file was perfectly in sync.
    about avstodvd, i added two audio tracks, one was commentary, i was hoping that somehow a menu would magically appear, but i cant access the commentary audio file, but i believe its located somewhere on the stream (vobs), wouldn't it be? since i selected both audios when processing it through avstodvd. Question, if i use the menu editor i avstodvd will it somehow make a method to access the commentary audio, or do i have to mux each audio source with the original video source effectively cutting my available disk near in half?
    Mar 2008
    Can't you access the 2nd audio scream by selecting it from your player using the remote control ?
  6. Member wolfdogg's Avatar
    May 2011
    Portland, OR, USA
    well, it looks like i can do even less than that. i only tried it on my pc, no menu so didnt think there was even that option. now that i put it in my dvd player, looks like its a frisbee. "disc cannot be played, plesae check the tv systesm" DOH. so what the heck did i forget to do in avstodvd to make it dvd player compatible?
    i wonder it its the audio file thats causing it, because the 2nd disk i made via avstodvd is able to play in my stand alone dvd player, i just checked.
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I think AVS2DVD defaults to making PAL-format DVDs, and your DVD player probably doesn't like that format. It can be changed in AVS2DVD's settings - but I'm not at a system with it installed, at the moment, so I can't check.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, try change to NTSC under Preference->Video->DVD Video Standard.
    And how did you burn it? Burn the ISO or VIDEO_TS folder with Imgburn.
    Mar 2008
    The Preferences, setting your NTSC/PAL choice and temp/output paths are the first things to do in this program,
    and save them as default. I'm not sure if AVStoDVD makes this clear to the new user.
