I am converting lots of DVDs i own to MP4 as they will be roughly 2 - 4gb each in size.
My concern is that with Ripbot the only audio options i have are AAC. There doesnt seem to be an option to copyaudio! Or is there?
With ripbot converting Blurays i have the option to copyaudio stream.
My other option is to use handbrake as i can see in the user guides on here it gives the option to AC3/ AAC and copy audio.
Wonder if you can get other audio settings for ripbot??
Also with the Video profiles of 4.0, 4.1 etc what do all these mean. I currently have it on 4.1 and slow.
Results 1 to 9 of 9
Ok that would make sence. Im doing them mp4 so they play on my ps3. Will the AAC 320 sound be just as good as AC3.
http://forum.doom9.org/showthread.php?t=127611Also with the Video profiles of 4.0, 4.1 etc what do all these mean. I currently have it on 4.1 and slow.
AAC (Advanced Audio Codec) 320kbps = AC3 640kbps = DTS 1536kbps in terms of quality.Ok that would make sence. Im doing them mp4 so they play on my ps3. Will the AAC 320 sound be just as good as AC3. -
the audio would sound about the same. Only difference is compatibility. I'm in the same boat. I want an ac3 192 audio option and Ripbot doesn't give it to you so I have to use another app like Vidcoder to get it. Vidcoder works great but the scripts/options aren't as great and the "grain" detail doesn't look as good as Ripbot or BDRB.
Since I can't get BD Rebuilder to work I use Vidcoder. I trade off the Ac3 audio for the minor video encoding issues. If Vidcoder offered more Video scripts/options then I would be onboard with it 100% but Ripbot produces a slightly better picture. As Ripbot doesn't do AC3 192, thats a big no-no for me. Amazes me that that great app doesnt have a an AC3 option. -
AC3 in mp4 is not officially allowed so PS3 won't give any sound
http://en.wikipedia.org/wiki/MPEG-4_Part_14#Data_streams -
AC3 in m2ts works but in MP4 container audio won't be recognizedThats interesting about AC3 and the ps3 not working.
So in MP4 container AC3 is best to use.
In a MKV container im best to use AAC. Is this right. Is AAC just compressed more then AC3.
RipBot264 Audio Sync Problems
By gonzalu in forum Video ConversionReplies: 7Last Post: 25th Sep 2024, 20:40 -
Multiple audio structures in same film using Ripbot264
By rocks911 in forum Video ConversionReplies: 1Last Post: 7th Dec 2011, 10:09 -
Audio during commericals, none during show in RipBot264
By tsservo in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2011, 04:43 -
Audio sync problem with RipBot264
By DirkGently68 in forum Video ConversionReplies: 2Last Post: 20th Nov 2010, 13:06 -
RipBot264 startup options
By leghorn in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 13:09
