im trying to convert audio in an mp4 video
the video is avc, the audio is ac3
im trying to get a new mp4 file with the same video codec, but converted audio to wav
i used this commandi get this errorCode:ffmpeg -i input.mp4 -vcodec copy -acodec pcm_s16le output.mp4maybe i should give the whole command line outputCode:Could not write header for output file #0 (incorrect codec parameters ?)
Code:FFmpeg version SVN-r18709, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --enable-memalign-hack --prefix=/mingw --cross-prefix=i686-ming w32- --cc=ccache-i686-mingw32-gcc --target-os=mingw32 --arch=i686 --cpu=i686 --e nable-avisynth --enable-gpl --enable-zlib --enable-bzlib --enable-libgsm --enabl e-libfaac --enable-libfaad --enable-pthreads --enable-libvorbis --enable-libtheo ra --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libxvid - -enable-libschroedinger --enable-libx264 libavutil 50. 3. 0 / 50. 3. 0 libavcodec 52.27. 0 / 52.27. 0 libavformat 52.32. 0 / 52.32. 0 libavdevice 52. 2. 0 / 52. 2. 0 libswscale 0. 7. 1 / 0. 7. 1 built on Apr 28 2009 04:04:42, gcc: 4.2.4 Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/ 1001) -> 23.98 (24000/1001) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\Stuff\Toy Story 1995 2010 Trilogy Bl uray 720p x264 ac3\Toy Story 1 1995.mp4': Duration: 01:21:03.44, start: 0.000000, bitrate: 2387 kb/s Stream #0.0(und): Video: h264, yuv420p, 1280x720, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0.1(eng): Audio: ac3, 48000 Hz, stereo, s16 [mp4 @ 0x13acff0]track 1: could not find tag, codec not currently supported in c ontainer Output #0, mp4, to 'D:\Stuff\Toy Story 1995 2010 Trilogy Bluray 720p x264 ac3\to ystory1.mp4': Stream #0.0(und): Video: libx264, yuv420p, 1280x720, q=2-31, 48k tbn, 23.98 tbc Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Could not write header for output file #0 (incorrect codec parameters ?)
Only PCM audio is uncompressed. You could try to mux it in a mov container.
You may need to update your FFmpeg version.Code:ffmpeg -i input.mp4 -vcodec copy -acodec pcm_s16le output.mov
http://oss.netfarm.it/mplayer-win32.php
You also need to download the faac encoder dll (also on that webpage) and put it together with FFmpeg. -
Thanks a lot Chris K.
your post helps me too much. thanks you. hope someone will be help.
mp4 to mpeg with ffmpeg - no audio
By ilpilo in forum Video ConversionReplies: 15Last Post: 29th Mar 2012, 10:17 -
Convert MKV with .ass subs to mp4 with ffmpeg
By bearnado in forum Video ConversionReplies: 2Last Post: 1st Mar 2012, 03:21 -
[FFmpeg] Unsynched audio in MP4
By Klagar in forum Video ConversionReplies: 4Last Post: 4th Aug 2011, 14:52 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
ffmpeg on Linux Error - .avi to mp4
By coolboarderguy in forum Video ConversionReplies: 10Last Post: 5th Nov 2007, 10:10
