hello
i did a format to my camcorder hdr sr-12 by a mistake and i wanted to know how can i use the camcorder again, i do not need any data recovery just want to film again.
what do i need to do? can you help me please?
thanks
Results 1 to 10 of 10
if all you did was format(erase) the hard drive, it should be fine. press record.
thanks but that is the first thing i tried to do and it says "hdd format error" and
not let me do nothing.
i tried to do format in a different way but nothing changed.
maybe i need to download something but i don't know what.
maybe you have a friend that know something about it?
i realy do not know what to do
please. -
if it's under warranty send it to a service center, there isn't anything else you can do to fix it. if it isn't, try recording to an sd card, if that doesn't work either then i'd start looking for a new cam.
I have an SR12. Formatting the HDD automatically comes from choices on the menu and shouldn't make the HDD fail. But HDDs fail anyway, formatting notwithstanding. You can use Sony's rabid memory stick and choose to record your movies there instead; there is a menu option that asks if you like to record to HDD or memory schtick.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
thanks but my touch screen doesn't work so i can use only with the computer. i also don't have a memory stick and even if i had, it doesn't solve the problem with the hard disk.
thanks anyway. i will wait until a solution will come from somewhere. i wish it will be soon... -
There's your problem: your touchscreen doesn't work. Formatting the HDD inside the SR12 is a process unique to that camcorder that has to be initiated within the camcorder, ergo, it HAS to be done with the touchscreen. I think if you go through the instruction manual it says there somewhere that deliberately formatting the HDD connected through USB by a computer MAY NOT make it work afterwards. Note that just because you can see the HDD structure and contents when it is in PC mode does NOT necessarily mean you can tinker away with it; there will be hidden files, folders, probably even a filesystem that's slightly or grossly different from either FAT32 or NTFS unique to the SR12 that only it alone can generate. There's also the problem of initializing the HDD, which can't be done from the PC unless, I suppose, you have the appropriate programs from Sony and others. Lastly, you need the touchscreen to deliberately get into and out of USB PC mode; merely plugging the USB cable in and out is NOT enough. This problem is not unique to the SR12; many PVRs, when disconnecting from the box and putting in a PC the contents can't be seen. I also have a Hitachi external USB HDD, which when I removed from the case, I couldn't access the contents via direct SATA on the PC. If you love that SR12 that much you will want to have the evil touchscreen repaired 1st and foremost. So there.
I would suggest finding someone with an identical camcorder. Have them format their camcorder using the touchscreen in the proper way. Connect their camcorder to a computer. Copy the blank AVCHD file structure that their camcorder produced during the format initialization onto your computer. Now copy that AVCHD file structure onto your camcorder.
How can I extract an HD video from sony HDR-XR550 camcorder?
By freestyler09 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Dec 2010, 06:40 -
How about the Sony HDR-XR150 Camcorder?
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Aug 2010, 18:07 -
Creating DVD from Sony HD camcorder HDR SR11
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2010, 08:46 -
HDR-SR5 Camcorder and MPEG transport stream
By raysolomon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th Mar 2009, 00:00 -
Re: Sony Digital Camcorder HDR TG3E Various
By billbirchall in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 13:06
