I've seen other threads about multiple movies on one blu-ray disc, but they all seem to be about re-encoding, etc. My situation is that I have two .ts files that are fully blu-ray compliant, one is 13G and the other is 9G. Of course, I'd like to put both these on one BD-R25 without a re-encode, since the files don't need it. Is there a program which will simply author a disc with two movies without a re-encode? (preferably a program other than multiAVCHD, which refuses to work right on my computer and has caused me nothing but problems in all my attempts to use it) I don't really care about fancy menus, etc. Even if I have to skip through all the chapters of the first movie to get to the second, I don't really mind. I just want them both on one disc, no re-encode. Thanks for any help.
If the original BluRay disc is single layer sized (you don't say one way or the other) this is insanely easy.
1) Rip with AnyDVD, DVDFab, DVDFab Pass Key - whatever you have.
2) Use ImgBurn to burn the rip with no changes.
Poof - you have a copy of the BluRay that works.
Getting rid of any extras is the tricky part. You might look into tsmuxer, which could generate a simple BD disc without menus. I have not yet tried it with multiple input files but I think it would work if you just wanted to input 2 movies into it. You're on your own at going from a BD rip to 2 separate input files that tsmuxer can deal with. Maybe someone else can help you with that.
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 16:40 -
convert non blu ray movie to blu ray disc???
By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 18:51 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
