It's in the camcorder, at least according to this article.
See this link: http://www.dvcentral.org/qpc.html
The article goes on to explain that "DV capture" is a misnomer, that a DV with Firewire is data transmission. No capture is going on.
Comments?
*Windows XP Home w/NTFS
*Soyo DRAGON Plus
*Athlon XP 1700+ OC’d
*ALPHA PAL8045U
*Kingston 256MB PC2100
*WD 400BB 7200RPM, 40GB, Qty 2 for RAID 1
*WD1200BB 7200RPM, 120GB
*TDK 24/10/40 VeloCD
*3dfx Voodoo3 2000 w/16MB -
Yes, that is correct; camcorders come with codecs already. And that firewire does NOT capture, but transfer the compressed video file from tape to your HD. Firewire is a PORT.
But then, keep in mind that a computer is a DUMB machine, it won't do anything unless you tell it what to do (sounds like LEMMINGS). The video files transferred to your harddrive would just be like a deadfile, unless you use a codec to decode them to useful video. And you need to do this if you want to 'play with' your transferred video.
my 2cents. -
I think most of the people already knew that DV capture is really just a transfer. 8)
Any ideas why the color is better on the Dazzle than with the Sony analog passthrough? ...both being played with Media Player?
*Soyo DRAGON Plus
*ALPHA PAL8045U
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
Which Codec should I capture in for MiniDV over Firewire
By AussieHusky in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Oct 2007, 22:33 -
Tranfer DV from SONY DCR-PC7 via Firewire to computer
By riverdaleDV in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 12:10 -
Panasonic PV–GS19 firewire connection - computer can't read it
By rbenjamin in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2007, 10:48
