Results 1 to 19 of 19
  1. Can anyone do me a batch script that will take a folder of mkv files, demux them, then mux the h.264 and audio stream into an mp4 file with the same title?
  2. Is there only 1 video track and 1 audio track?
    It's probably easier with ffmpeg
    for %%a in ("*.mkv") do ffmpeg -i %%a -vcodec copy -acodec copy %%~na.mp4
    pause
  3. Yeah only one of each. I'll give that a go
  4. Tried that, I get this
    C:\Users\Michael\Downloads\ffmpeg-git-01fcbdf-win32-static\ffmpeg-git-01fcbdf-win32-stat
    ic\bin>for %%a in ("C:\Users\Michael\Desktop\Season 2\*.mkv") do ffmpeg -i %%a -vcodec c
    %%a was unexpected at this time.
    ic\bin>pause
  5. sorry - misunderstanding
  6. Thanks but now it doesn't like the spaces in the path. I have it in " " though
  7. It's a dos batch file - i.e. open notepad .txt file in same directory as video files, along with a copy of ffmpeg.exe , copy & paste code, rename .txt extension to .bat, double click the .bat to re-wrap
    If you have spaces in filenames, put "" around it
    for %%a in ("*.mkv") do ffmpeg -i "%%a" -vcodec copy -acodec copy "%%~na.mp4"
    pause
  8. Works like a charm, much better than the way I was doing it.
    Is there a different method to doing it with avi's (to mp4's), I tried but by changing the mkv to avi and when I tried to add to zune (to sync with my phone) I get 'media type not valid'. Not sure if that's because it's not packaged correctly though
  9. Is there a different method to doing it with avi's (to mp4's), I tried but by changing the mkv to avi and when I tried to add to zune (to sync with my phone) I get 'media type not valid'. Not sure if that's because it's not packaged correctly though
    Same thing, just change "mkv" to "avi"
    for %%a in ("*.avi") do ffmpeg -i "%%a" -vcodec copy -acodec copy "%%~na.mp4"
    pause
    The only things that you might need to change , are when there are multiple streams (e.g. 2 audio ), or if the stream number is different (e.g. video is track 1 instead of track 0) . Then you can use -map command
  10. Hmmm not sure why it doesn't like these mp4's then :/
  11. the mkv to mp4's play on the zune? but the avi to mp4 doesn't ?
    what kind of compression ? what specs ? use mediainfo view=>text , then copy & paste the report back here
    some types of encoding settings (either audio or video) make the video unplayable on devices. The only way is to re-encode those; you cannot just copy the video or audio stream
  12. Is this a standard thing to see during avi to mp4?
  13. Just saw your reply, here you go
    ===================== General =====================
    Complete name : C:\Users\Michael\Desktop\sd\Hustle Season 2 Episode 5 - Old Acquiantance.avi
    Format : AVI
    Format info : Audio Video Interleave
    File size : 440 MB
    Duration (ms) : 59mn 42s
    Total bitrate : 1 031 Kbps
    Comment : Joined with EO VideoNew value: %d... /
    ===================== Video =====================
    Format : MPEG-4 Visual
    Format settings - BVOP : Yes
    Format settings - QPel : No
    Format settings - GMC : No warppoints
    Format settings - Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec Id : DX50
    Codec : DivX 5
    Bitrate : 889 Kbps
    Width : 720 pixels
    Height : 400 pixels
    Aspect ratio : 16:9
    Framerate : 25.000 fps
    Colorimetry : YUV
    Colos space : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.123
    Stream size : 380 MB (86%)
    Title : Video
    Encoded library : DivX 5.2.0 (DrDivX 105) (UTC 2004-07-17)
    ===================== Audio =====================
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format settings mode : Joint stereo
    Format settings mode extens : MS Stereo
    Codec Id : 55
    Codec : MP3
    Bitrate mode : Variable
    Bitrate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 55.3 MB (13%)
    Alignement : Aligned on interleaves
    Interleave duration : 26 ms (0.65 video frame)
    Interleave preload : 117 ms
    Title : Audio
    Encoded library : LAME3.92
    I was hoping I wouldn't have to reencode, but I might just need to give these ones a miss
  14. Does the re-wrapped video play on a PC media player ?
    Try ffmbc instead, and modify the batch script
    You can find binaries here
    http://www.mediafire.com/?8xynxe10rxb88
  15. Yeah it plays fine. I'll try that cheers
  16. Nope. Not working either.
    This zune software is awwwwwful.
  17. What about mp4box - mymp4box, yamb ? Do they play when remuxed with those
    If not, it's probably an issue with zune then ? with xvid/divx
  18. Yeah tried mymp4box. Didn't work with that. I think it must just be the codec.
    ah well, thanks for your help. I can use that batch file for all my mkv's
  19. Hi again,
    Would it be possible for someone to edit that batch file to check for one of a list of audio codecs then if it matches, convert to mp3 or aac but keep the video stream the same?
