And a sample will be helpful to see what's going on. It's not generally a good idea to buy a PAL version of anime (if it's anime). Maybe it's field-blended from a bad NTSC to PAL conversion. Yes, I understand you were told it was region-free (also implying it's a bootleg).
Results 31 to 33 of 33
Yes I am aware that you can fix it. Ive only came across this once before though and someone helped me with the line I needed to add to my script. So sadly I dont know what to add into avisynth to fix the ghosting on my own. I havent encountered it enough.
Ill put up a sample soon when I can get around to it. -
Its not anime, its this http://www.amazon.com/Mighty-Morphin-Power-Rangers-Classixx/dp/B000O59Z6G/ref=sr_1_2?s...8635886&sr=1-2
and the ghosting is there in the VOB before I even tried to convert it.
Ill get a sample up asap when I can get around to it.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
Convert PAL to NTSC?
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 20:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
