hello everybody, im trying to convert an .mkv video with resolution 1280x534 (DAR 2.40?) for a CRT tv with a 16:9 panel. This file has to be converted to .avi since it's the only available format for the player connected to the tv. The player can handle up to 720x576 xvid ASP@5 resolution (this is what i got from the manual). Im not an expert so forgive my stupid question, if i dont want the video to be letterboxed, i should resize the video to 720x405, in this way i get a 1,78 DAR and no black stripes on the TV...right? But if i do so, i get a squeezed video on the horizontal resolution...is there any way i can resample the original video to get both a 16:9 stream and the right proportions?
thanks in advance
				Results 1 to 29 of 29
	You must crop the sides then. Last edited by Baldrick; 6th Feb 2012 at 11:40.
	thanks for your fast answer! mmm...ok so i should cut some unwanted parts from the original mkv in order to get 720x405 and the right proportiions? just trying to understand better.
	Well, they might not be unwanted...so it always best to leave it as 2.40:1 if you want the entire image.
 What do you convert with now? Most good converter should be able to crop video.
	ah ok so i keep it 2.40:1, anyway i downloaded a few programs and now im getting used to virtualdub, in this case i have to crop the converted .avi since i cant open an mkv using virtualdub.
 thanks for all the info!
	ok i still cant get the wanted result, i decided not to crop the original mkv, so i resized the video to 720x404 with a PAR 1.0. I thought i was going to get a full screen video on my tv but i still have 2 black bars, thinner than the ones i got before but not a full screen. Why ? I thought i created a 16:9 video stream.
 thanks for your help!
	With all due respect, you should get used to the 'black bars'.  Have a good one, Have a good one,
 neomaine
 NEW! VideoHelp.com F@H team 166011!
 http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
 Folding@Home FAQ and download: http://folding.stanford.edu/
	it's not a problem for me, im simply trying to learn something  i thought i was going to create a 16:9 video but it doesnt seem so i thought i was going to create a 16:9 video but it doesnt seem so ...so im asking just for understanding better, i dont care so much if the black bars are still there, but i want to understand why! ...so im asking just for understanding better, i dont care so much if the black bars are still there, but i want to understand why!
 thanks
	It looks like you encoded it right (although since you resized the entire 1280x534 frame down to 720x404 everything is horizontally squished -- but that's apparently what you wanted). You're using a DVD player to play the video on your 16:9 HDTV? You probably have the player or TV set up wrong. What type of cable are you using? HDMI? Composite? Is it an upscaling player? I suspect the player is set to output 4:3 and the TV is set to stretch 4:3 to 16:9. You want the player to output 16:9 and the TV to keep that AR.
	Ok there is a setup problem i guess, i tried to load a standard dvd with the dvd player (which is different from the player i use for .avi files) and on the same tv i see it with the same black boxes...so the tv has to be setup i guess.
	ok i realized that the .avi player has some strange behaviour (this crappy model: http://www.dikom.it/en/prodotti-dvbt/dvbt_135SCART.html ). I tried to record directly from the tv using this player, and it recorded an .mpg file that can be played at full screen. Using mediacoder on the file i got the following specs:
 resolution: 720x576
 aspect ratio (16:9)
 pixel aspect ratio 1.42
 i dont understand where does the 16:9 aspect ratio come from, considering it is 720x576 (1.25) with PAR 1.42 (no idea why)
	ok but from what i know i should have SARxPAR = DAR, in this case SAR = 720/576, PAR = 1.42 and DAR = ....1.78 (16:9) ??
	thanks!, sorry if i look stupid ...i tried to calculate it and i got something different from DAR = 1.78 so i was having problems understanding  Now i have the right result 1.25*1.42 = 1.775 ... Now i have the right result 1.25*1.42 = 1.775 ...
 but if SAR can be only 1:1 how can i have a file with a 720x576 ? shouldnt it be like 500x500 or 720x720 or anything like SIZExSIZE ?Yes. Note that MPG flags only supports 3 DARs and one SAR: 4:3, 16:9, 2.21:1 DAR, and 1;1 SAR.
	ah ok, thanks again. So in conclusion...since the .mpg created by the video player itself is working right at 16:9 with a frame resolution of 720x576 and PAR 1.42, i should convert my .avi using the same parameters?
	ok i think i definitely got it, in order to obtain a PAL widescreen i need to use a PAR of 1.42 (teorically 1.45). This value was calculated as the optimal value for showing PAL anamorphic wide screen, considering that analog TV screens dont have a vertical resolution but the analog signals are resampled creating non-square pixels with a resolution of 720x576 .
 this is what i got from googling around for an hour, now i think i have it clear
	 ok the .avi file 720x576 + PAR 1.42 still shows black bars, while the .mpg doesnt, i dont know what to think now. ok the .avi file 720x576 + PAR 1.42 still shows black bars, while the .mpg doesnt, i dont know what to think now.
	ok...i will try to convert it to mpg and see if it can handle the flags correctly in this last case! So this means that maybe the first .AVI file i made with a 720x405 resolution and PAR 1.0 was correct?Your player, like many, doesn't support Xvid PAR/DAR flags properly.
 thanks..im going to sleep!
	It sounds like the file you originally made was fine. Except many player will not play a Xvid file with an odd frame width or height -- in this case 405. you should always use mod4 (integer multiples of 4) at least. Mod8 and Mod16 are even more compatible and efficient.
	ok using an MPG container and mpeg2 codec keeping 720x576 PAR 1.42 it shows up correctly
 thanks jagabo!
	Note that with MPEG 2 you are specifying the DAR, not the PAR. I've seen a few DVD players that had problems playing bare MPG files with the correct DAR (ie, the need a full VIDEO_TS, IFO/VOB structure).
	The difference between setting the PAR and the DAR is important when you are cropping a video. Say you have a 2.35:1 movie encoded on a 16:9 DVD. If you leave the frame at 720x576 and encode with the 16:9 DAR flag the video will display properly. But if you crop away the black borders, leaving a 720x432 frame, and encode that with a 16:9 DAR flag it will display incorrectly -- because the correct DAR is now 2:35:1, not 1.78:1. On the other hand, when using codecs that support PAR you can use the same PAR (1.42 in this case) for both videos because cropping the border has no effect on the shape of the remaining pixels.
	mmm this further explanations made a little of confusion in my mind, why the correct DAR is 2.35:1 if i crop the video?
  [SOLVED] How to tag an mkv/mka file?By bat999 in forum Newbie / General discussionsReplies: 13Last Post: 24th Jun 2018, 15:20
  1080p MKV Choppy Playback - Solved!By sdbyrd in forum Software PlayingReplies: 5Last Post: 13th May 2013, 07:29
  Need help in resize mkv for use on tabletBy chong67 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2011, 16:14
  [solved] editing MKV without remuxingBy lovelove in forum Newbie / General discussionsReplies: 4Last Post: 12th Aug 2011, 10:09
  Resize MKVBy joe1974 in forum MacReplies: 1Last Post: 11th Jun 2010, 11:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
