Hi,
anyone there with an idea, which tool i can use for muxxing mkv files to m2ts (each filename of the mkv should be the filename of the m2ts). TSMuxer outputs the mkv files in one big m2ts, but thats not what i want.
Thx
j.
Maybe you could write some batch file for the command line version of the tsmuxer...but it will probably be very complex.
Or some of the mkv to avchd converters, like mkv2vob, it will create a bdmv/stream/0001.m2ts for each mkv. Under Configuring choose Output type AVCHD - Disc and then choose Directory to convert the entire folder. To avoid any video conversion select Video Transcoding: None under Configuration.
How to mux .264 and .wav files to .m2ts or .mp4 using FFmpeg????
By rallymax in forum EditingReplies: 1Last Post: 31st Oct 2011, 17:04 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 14:45 -
mkv or m2ts container files?
By runLoganrun in forum Software PlayingReplies: 1Last Post: 8th Dec 2008, 11:50 -
Combine mkv or m2ts files
By BDR in forum EditingReplies: 0Last Post: 25th Feb 2008, 04:31 -
Blu ray m2ts files not in order? mkv conversion
By davidc78au in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 11:39
