I have a .DTS track that I'd love to merge with my mkv file because it only has AC3 track. I used MkvMerge to mux it, everything went fine, but than I couldn't play it on my LG BD570 Blu-Ray player, because when I pressed play it showed a black screen & than it threw me back to the main menu.
I don't know what I did wrong. Please help
Did you disable header compression? Under File->Options and select "Disable header removal compression...." in mkvmergegui. Then open your mkv and remux it and it will probably work better.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Best Blu Ray Player to play 3D MKV (DTS audio) files off my USB HDD?
By Freaz in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Apr 2012, 23:15 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Remuxing Blu-ray .M2TS to .MKV using DTS-MA?
By ejp in forum Blu-ray RippingReplies: 6Last Post: 31st Oct 2008, 11:56
