can anyone help i looking for a firmware update for the liteon hbs112 bluray burner is this available![]()
According to Liteon's website(found via a simple 13 second Google search), there is no firmware update for this drive. Who told you there was an update for it and what did you expect the firmware to fix?
thanks any way i was 99% sure there wasnt one but just wanted to check anyway the reason being i had a lg bh10ls30 burner when i burnt a bluray movie it would only play on the lg stand alone player and not the sony stand alone but i upgraded the firm ware yesterday for the lg burner and tried it on the sony and it played so i thourght it would probably work for the liteon burner if i would find the firmware
ahhh...so much kindness(found via a simple 13 second Google search)
i have the same drive and i believe these lite-on br drives are proprietary(i could be wrong but i myself have searched high and low)....theres not an update and probably wont be one. My drive does excellent with verbatim discs -
If you aren't using CL0K, yes there is an updated version available.
http://www.firmwarehq.com/Lite-On/iHBS112%2B2/files.html -
thanks thats made my day the old firmware was cl04 they now play on my sony stand alone
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 21:58 -
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 16:28 -
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 16:32 -
Help Liteon DVD recoder
By killingme in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Apr 2009, 18:46 -
change hd in liteon 5025
By DENAR in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Sep 2007, 12:47
