Hey everybody,
Are there any hardware VHS to DVD units that can automatically create a menu for converted videos?
I'm looking at buying one, however I will be using it to convert VHS to DVD for other people (sort of like an extra service in my business.)
Thanks in advance![]()
1) Weekends are down times for the forum. A lot of our regular members get on with their lives then.
2) Yesterday was - http://en.wikipedia.org/wiki/Super_Bowl
This is why nobody in the USA cared about the forum yesterday. It's very close to being a national holiday. How do you not know about this? Are you an Aussie or a Kiwi? (Brits know about it. So do Canadians.)
What exactly does "hardware VHS to DVD units" even mean? Are you asking about DVD recorders (which will create menus) or are you talking about some kind of video capture card? You do yourself no favors when you use vague and unfamiliar terms to describe what you want. -
Yes I am Australian and there's no need for condescension at all.
Anyway, I'm talking about a hardware device that has both a DVD drive and a VHS slot and can record straight to DVD from the video being played (but also automatically create a menu so that the resulting DVD won't play automatically) -
There are plenty of VHS Player - DVD Recorder units available....and I think you will have trouble finding one that DOESN'T create a menu on the resulting DVD that you record.
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 18:57 -
Buying advice - Should LCD TV or blu-ray DVD player have Wifi capability?
By coody in forum DVB / IPTVReplies: 2Last Post: 11th Dec 2010, 11:52 -
WD TV capability
By jayantadak in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Apr 2010, 23:00 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
DV AVI to WAV problem, exports in Units? then no dvd SYNC
By mrmoodswing in forum Capturing and VCRReplies: 0Last Post: 20th Jul 2008, 17:35
