Apparently there is some type of protection in the files that I cannot combine them in the usual way (YAMB) so is there a way to remove the protection and combine them, if you without re-encoding I would be a very happy customer.
When man discovered milk came from cows, what did he THINK he was doing?
If there was protection, you wouldn't be able to play them.
More likely is that they have a different spec -- framesize, audio sampling rate, etc, etc.
How about Avidemux?
Just open and resave with audio and video set to COPY (thus no reencoding) into the same container. That often fixes any weirdness.
Otherwise, put them in Avisynth, use info() to find out their spec and change each to match.
FFmpegSource2 is good to input them.
Code:FFmpegSource2("Torn-1.mp4",atrack=-1,fpsnum=-1,fpsden=1) info() -
Sorry forgot to mention Avidemux complains that H.264 is detected and not enabling the safe mode crashes and enabled gives me weird playback every time.
The files will only play on the computer. If I stream them (TVersity) to the Xbox no dice. Hadn't thought to put it on a thumbdrive but I doubt that will help.When man discovered milk came from cows, what did he THINK he was doing?
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 15:43 -
Combining MP4 files (h264) with mencoder results in blank (white) videos
By mstaker in forum Video ConversionReplies: 0Last Post: 10th Dec 2011, 15:35 -
combining MP4 and MTS files
By mikey111k in forum EditingReplies: 3Last Post: 2nd Nov 2010, 05:05 -
Combining MP4 files
By Shaba1 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2009, 18:46 -
Combining Sony mpeg2 files with m2ts files
By hsid in forum EditingReplies: 8Last Post: 2nd Mar 2008, 21:51
