  1. I have been doing music videos for a while now and my music videos now do not seem to deinterlace I have checked the option for it to be enabled and I have unchecked the inrerlace option in tmpeg 12a.
    Anyone have any ideas of what might be doing this? I thought it might have been a hard drive problem so I formatted today hoping that would fix it but it didn't
  2. Did you select a deinterlacing method? You can't just check the box you need to double click
    Also tried to use the Inverse Telecine method?
  3. yeah I did select the deinterlace method Inverse Tecline doesn't work with PAL videos for some reason. That is more geared for umm NTSC
