Results 1 to 11 of 11
    Jul 2006
    I have a huge file which resulted from an camera being unattended (as I forgot to turn it off).
    Only want the first couple of minutes as the rest is garbage.
    My goal is to retain those few minutes and discard the rest in order to not waste HD space whihc is precious.
    Suggestions please? What are the best tools here that will split that files where its needed?
    Oct 2005
    666th portal
    if you have vegas pro 11 you might be able to cut out the piece you want and do a no-recode render. what cam was it?
    Jul 2006
    Bought a brand new A1s. My second.
    All of 2 days old.
    Do not have VP 11.
    Any tool in this forum will do the job?
    Apr 2007
    Australia
    Try this. Worked with my JVC clip.
    The program complained but it still worked.
    http://rocketjet4.tripod.com/Mpg2Cut2.htm
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    All of 2 days old.
    Do not have VP 11.
    What is an A1? How are we to know?
    This? http://en.wikipedia.org/wiki/Canon_A-1
    http://www.a1securitycameras.com/A1.html
    http://dv12.blogspot.com/2012/01/bubbas-gopro-helmet-cam-a1.html
    http://pro.sony.com/bbsc/ssr/cat-recmedia/cat-recmediahdv/product-HVRA1U/
    http://www.kiva.org/about
  6. Member edDV's Avatar
    Mar 2004
    If a Canon XH-A1 (just guessing), try HDTV2MPeg2 to cut HDV video on I frames.
    What edit software do you have?
  7. What are my options for splitting a .m2t file?
    One option is MediaCoder. is has a "Time" tab with a "Select" button that allows you to visually set the start/end for the split.
    I don't know if MediaCoder is the best tool for you - for me it is. It might seem a bit overwhelming at first if you are not familiar with the program but then this Tutorial might be helpfull.
    Jul 2006
    Thanks Gents for your suggestions and options.
    I will pursue the best solution from the ones mentioned.
  9. Member edDV's Avatar
    Mar 2004
    So you don't even know what an "A1" is?
    Jul 2006
    An A1 camera or ancient camcorder with that designation.... no.
    I use a Canon XH-A1 just about every week. That's dated at this point too but very usefull.
  11. Member edDV's Avatar
    Mar 2004
    Then say XH-A1 and don't leave us guessing.
