I'm trying to use DVD+RWs in my Megastor 16XDVD9 with Imgburn. It doesn't seem to want to work. It wants to keep erasing and formatting the disk even though it's a brand-new disk.
Is the problem with Imgburn or with the Megastor?
Thanks,
Paul
The ONLY RW discs worth buying are Verbatim. That's it. You're wasting your money on any other brand.
It is hard to say what the problem is. RW discs aren't always reliable. I've even seen a few Verbatim RW discs have problems from the very first use. In my opinion ImgBurn does not excel at erasing RW discs. Nero gets a lot of crap around here and deservedly so for the most part, but it is excellent at erasing RW discs. If I need an RW disc erased and I don't have 10-15 minutes to wait on ImgBurn to do it then I just use Nero.
Do note that RW discs are NOT ready to use right from the pack so if you just opened it and expected it to be ready you are mistaken. They MUST be erased and formatted prior to a first use. Your post is unclear and it could be that everything is normal and you are just wrong in thinking that your disc would be ready to use on a first attempt without being formatted. -
Thanks so much for your thoughts. You are right: Everything was fine, it just took an inordinate amount of time to erase and format. Once it had, everything was fine.
Paul
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 21:59 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 14:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 13:51 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
