Trying to render a 2 minute video (with quite a lot of clips). I'm on the latest build of Vegas and it crashes as soon as I start rendering.
Here's the error message.
Problem Description
Application Name: Vegas Pro
Application Version: Version 11.0 (Build 520)
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 11.0\vegas110k.dll
Fault Address: ve
Fault Offset: 0x00057CA6
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 11.0\vegas110.exe
Process Version: Version 11.0 (Build 520)
Process Description: Vegas Pro
Process Image Date: 2012-01-16 (Mon Jan 16) 15:38:32
I have had a problem rendering with large videos before (freezes at about 8%...) but thought the latest build had fixed this. Apparently not.
Have you tried output with different video and audio codecs and see if it makes any difference?
preset or custom render?
As alluded to above, their deflault settings are way off. Make a custom setting and save it.
An "Unmanaged Exception" means something non-Vegas related.
Are you a dinkerer? If so, go back to the last thing you dinked with and undo it.
sony vegas not rendering all tracks
By nukegumbo in forum EditingReplies: 5Last Post: 30th Apr 2014, 16:22 -
Sony Vegas Rendering Problem
By LCSTutorials in forum EditingReplies: 0Last Post: 9th Aug 2010, 00:27 -
Sony Vegas 8.0 - error while rendering
By crystal_ in forum EditingReplies: 0Last Post: 9th Mar 2009, 23:25 -
Sony Vegas 8.0b - video rendering
By SNK in forum Video ConversionReplies: 13Last Post: 4th Nov 2008, 03:52 -
screensize rendering sony vegas
By stompinne in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 18:55
