Very interesting effect on fundamental operation.
Source clip:
http://www.mediafire.com/?z7gphh6g50btpj4
This is an exampled script, in dissolve area audio is stumbled.Code:clip = directshowsource("mvi_5433.mov") part1 = clip.trim(0, 100) part2 = clip.trim(200, 300) part3 = clip.trim(400, 500) return part1 + dissolve(part2, part3, 100) #Audio stumbled #return dissolve(part2, part3, 100) #Audio OK
Source:
h264, unkompressed audio 44 kHz/16 bit
Result:
xvid, unkompressed audio 44 kHz/16 bit
Encoding with VirtualDub
Can anybody help me?
Thanks.
P.S. Sorry for my bad english.
What do you mean by 'stumbled'?
If you mean there is an audio glitch or click, and only at the transition between part1 and the rest, try using a very short (eg 1 frame) dissolve instead of a hard splice for that join.
On the other hand, if you mean the audio is out of sync during all of the second part, it could be a problem with DirectShowSource, which is not guaranteed to be frame-accurate. In that case, try another source filter like ffms2.Code:part23 = dissolve(part2, part3, 50) return dissolve(part1, part23, 1)
You can see/hear the part of result of encoding (1,9 MB)What do you mean by 'stumbled'?
http://www.mediafire.com/?dwroa1belzfz8d5
This script has the same bad resulttry using a very short (eg 1 frame) dissolve instead of a hard splice for that join.
At first sight, FFmpegSource2 works fine. But I remember, this filter adds some artefacts at video. And who is decoding h.264 videostream? I not see the ffdshow icon in tray (default handler for h.264 video) while processing AVS-script with FFmpegSource2().try another source filter like ffms2
If I use directshowsource, I see this icon.Last edited by egochnpp; 4th Feb 2012 at 06:35.
If it really is giving problems with the video (and you should verify this), you could use it for audio only and continue getting the video from DirectShowSource:
Code:clip = directshowsource("mvi_5433.mov", audio=false) clip = clip.AudioDub(FFAudioSource("mvi_5433.mov"))FFmpegSource2 has the ffmpeg decoders built-in, and does not rely on installed codecs.And who is decoding h.264 videostream? I not see the ffdshow icon in tray (default handler for h.264 video) while processing AVS-script with FFmpegSource2().
If I use directshowsource, I see this icon. -
OK, this works very fine, thanks....you could use FFAudioSource() for audio only and continue getting the video from DirectShowSource
I found other ways to avoid problem:
1) AviSynth::directshowsource() -> VirtualDub -> LossLess Codec (e.g. HuffYUV ) -> AviSynth::avisource() -> VirtualDub -> XVID, but this way is very long.
2) mp4cam2avi (this application directly repacks MOV file to AVI without recoding) -> AviSynth::directshowsource() -> VirtualDub -> XVID
3) Install QuickTime Alternative -> Download QTSource Plugin -> AviSynth::QTInput() -> VirtualDub ->XVID, but this way has low quality of resulting videoclip.Last edited by egochnpp; 4th Feb 2012 at 09:42.
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 19:05 -
Low Quality on Dissolve Transition with Photos
By mattgx in forum EditingReplies: 22Last Post: 26th Jun 2009, 19:58 -
cut vs dissolve ...
By perik in forum EditingReplies: 3Last Post: 28th Dec 2008, 15:53 -
oops, I've stumbled into the wrong forum
By MackemX in forum Off topicReplies: 8Last Post: 1st Nov 2007, 15:27 -
Double audion when converting AVI to MP4
By avni in forum MacReplies: 0Last Post: 12th May 2007, 23:29
