a friend of mine gave me his laptop to figure out whats wrong it(1st he told me it's a virus).its a Toshiba Satellite A205 - S5814 .when I hit the power I hear the HD for few sec fan running, black screen with no post, no sound,,nothing. I know even with bad RAM or HD it should post. looks like a bad CPU or MB but I'm not sure yet.
any idea/tips ?
i'd start with re-seating the ram. remove, swap positions if there are 2, and re-insert. next i'd remove the battery and power cable, then hold down power button for 30 seconds. re-assemble and start. try clicking delete during power up to get to bios, or whatever key toshiba uses.
nothing worked.I even used one of my memory sticks. I put ubuntu CD just for the heck of it. I also noticed the battery doesn't hold a charge at all. as soon I removed the cord the power icon goes off
one more thing.the fan is running even when the lid is closed feels little bet warm -
that's what I think too.I just wanna be sure before I give him the bad news
Pull everything out and try again ... toshiba's are finicky about faulty hd communication ... if it's failing it can halt the system causing this symptom.
[QUOTE=Bjs;2138805]Pull everything out and try again ... toshiba's are finicky about faulty hd communication ... if it's failing it can halt the system causing this symptom.[/QUOTE
I'm running WD diagnostic on the hard drive now (Thermaltake BlacX Docking Station).it passed the 1st quick test and right now I'm running the extended test (1.30 min left)
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Need help with region change for Toshiba Satellite
By Magic Rose in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Apr 2010, 07:49 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Toshiba Satellite Vista laptop won't recognize ram upgrade
By edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
