Results 1 to 15 of 15
    Jul 2008
    How can you tell the quality of blank DVDs when buying them in a store? I want to make sure I buy high quality DVDs but I never know what to look for.
    Nov 2005
    if at all possible buy verbatim that come in these spindles
    do not buy verbatims that are called Value Line. I've used Radioshack's house brand called Gigaware and they scan out good. Used them for a few years and no problems. I also use TDK -r's I get from office depot and they scan out good to. No issues. If you buy online go to supermediastore and just grab the 50 pack of + or -r 8x verbatims...they're rock solid
  3. Member bendixG15's Avatar
    Aug 2004
    Educate yourself
    Spend time here ............ https://forum.videohelp.com/forums/28-Media
  4. The good ones say Verbatim DataLife Plus and AZO, or they say Taiyo Yuden. The others are hit and miss. Brands like Sony, TDK, etc. don't manufacture discs, they buy them from the companies that do. Sometimes they're good, sometimes not.
  5. Banned
    Freedonia
    DON'T BUY IN STORES!
    Honestly, the ONLY way to be sure you know what you are getting is to order online from rima.com, supermediastore.com, etc. Verbatim rarely sells their good discs in stores any more because the market demands cheap, low quality discs. You are just wasting your time trying to find good discs in stores. If you are too cheap to pay shipping (and honestly even with shipping ordering online is often as cheap or cheaper than buying in stores) then you really have no business looking for good media and should just buy whatever cheap crap you see in the stores that you can afford.
    Verbatim's value line series is called the "Life" series. Best Buy sells them. It's low priced crap but they are no worse than anybody else's low priced crap discs. Don't confuse the Life series with Verbatim's top of the line DataLifePlus discs which you can only buy online and are excellent.
    Jul 2008
    Thanks for all the info !
  7. ...C O P Y L E F T JohnnyBob's Avatar
    Feb 2007
    Earth
    Stick with Verbatim. They burn good and I've had zero compatibility problems.
    Here's the numbers to search for:
    95098 (SL +R 100 pack) <$20
    95102 (SL -R 100 pack) <$20
    96542 (DL 8x 30 pack) <$30
    Prices fluctuate and they're running a little high right now.
    If you wait & watch you can probably get the prices indicated.
    I usually catch the best deals at Amazon or Newegg.
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yep...
    Everyone else here always seem's to mention rima, supermediastore, etc......
    But I always seem to be able to get my Verbatim DVD+R & Bluray media from newegg for quite a bit cheaper.
    And when they have sale's on them.... they are way cheaper!!!
  9. Member zoobie's Avatar
    Feb 2005
    Florida
    I just saw Newegg on eBay of all places...Guess what they were selling?
  10. Banned
    Jun 2004
    Huh ??
    I have never seen or come across Newegg on Ebay but i have seen TigerDirect, BestBuy and a few other brick and mortar stores with Ebay stores selling stuff on Ebay.
    Now i am going to have to look on Ebay for Newegg
    EDIT:
    I was already on Ebay looking at/for different things, and i just looked up Newegg's Ebay store, and they are selling pretty much everything so a guess as to what you are referring to would be like playing the lottery!!
    LOL!!!
  11. Member zoobie's Avatar
    Feb 2005
    Florida
    Then you had to come back here quickly to edit your post
  12. Banned
    Jun 2004
    It's called "multiple tabs" in firefox....
    I have a minimum of 5 tabs (usually 6 or more) open anytime i am sitting in front of my PC....
    Mail, Vhelp, Newegg, Ebay, **** (Can't say, no it's not a pron site), Craigslist (always scanning for good deals) and maybe a couple of other random sites....
    It is 2012, not 1995 when you hope your dial up modem will connect and let you load 1 site within 5 minutes..... and you get to hear that cool screeching sound!!!
    LOL!!!
    And actually, i thought it took a long time... as i went upstairs to get pizza and my router went bonkers for a few minutes....
    But maybe the bourbon made it seem longer than it actually was
    LOL!!!
    Jan 2012
    Time for a stupid question. For which applications are -R and +R better? For instance, if I'm burning a movie to DVD to watch in a stand-alone player, do I use -R or +R? Ditto burning files to a DVD for storage?
    Thanks!
  14. Originally Posted by nfurlong View Post
    ...if I'm burning a movie to DVD to watch in a stand-alone player, do I use -R or +R? Ditto burning files to a DVD for storage?
    Doesn't matter in the least.
    Jul 2008
    Newegg has a promo code on their site for $5 dollars off 95098 but it's only good until 2/16/2012. Good deal
