  1. Member Deidara's Avatar
    Feb 2012
    I want to rip my Shippuuden DVDs onto my computer, They give the option for both Japanese and English languages. I want separate rips of each. (one rip in Japanese, other in English) I want to keep the exact same quality, size is no issue And also, their separated in episodes, how do I rip each episode, if possible? here is the DVD in question: http://www.walmart.com/ip/13867096
    I need to do this for free... Possible?
    Sep 2011
    I always use DVDfab, You can get the free version, When you go to copy to hard drive just choose which audio you want.
  3. Member Deidara's Avatar
    Feb 2012
    Thanks! Can you give me a link to the free version?
    Also, Will the files remain the same quality, and aspect ratio?
    DVDFab Decrypter. It's the same as the full DVDFab but when you start it you just select to run the free version. It can just copy the entire dvd.
    Yes, everything will be same.
    Sep 2011
    Yea, I should have said DVDFab Decrypter, Go here to download and for guides, https://www.videohelp.com/tools/DVDFab-Decrypter
  6. Member Deidara's Avatar
    Feb 2012
    Thanks guys!!!
