  1. I have 4 .ts files that I captured with a Hauppauge Collosus card from a HD cable DVR. I cut the commericals out with TSSniper. They were originally m2ts files but it saved them as .ts files. Anyway they play fine on the PC.
    I used DVD Architect Studio 5.0 so I could make a menu and burn to a BD-25 blu-ray disc.
    However I'm getting no sound and the files play at like double speed.
    What am I doing wrong?
    Thanks,
    MC
    In DVD Architect or after you have exported? If just in dvd architect then try export to a blu-ray/avchd on your hdd and test play with for example TMT.
  3. It does it on both. I didn't notice it until I had burned the bluray disc. I checked in DVD Architect and sure enough there's no sound for either of the 4 files and they move rather quickly.
    If I play the 4 files in media player or media player classic or TSsniper they play correctly. Could it be that DVD Architect doesn't support using .ts files?
    This has been a nightmare. I got the hauppauge pvr thinking I could easily capture things from my HD cable DVR and put them on blu-ray discs.
    I captured in .ts at first and was trying to use multiAVCHD to get menus. However the audio conversion failed. So I captured in .m2ts and it worked however the audio is out of sync (on the blu-ray disc only).
    So I invested in DVD Architect Studio and thought that it would work great. However now I'm getting no sound and double speed video. I never would have thought it would be THIS HARD to capture some 1hr videos and burn them to blu-ray. It's unreal. Any help would be appreciated.
