I'm having an issue with an mp4 file. I'm trying to convert this to a dvd using AVStoDVD, however the file is too big to fit on the disc as one. How do I split an mp4 file in half for dvd conversion. Any help would be appreciated. Thank you
Whats the video length/runtime? You should be able to adjust the bitrate so it fits.
But you can split mp4s with for example mymp4boxgui (under split) or with avidemux(open mp4, set start and stop, save as new mp4). -
The video's runtime is 4 hours and 23 minutes. I'll try these programs to see what happens and will report back. Thanks for the input.
Tried using mymp4boxgui to split the file and when I did the audio became out of sync. Anyway to fix this?
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 15th Nov 2023, 23:16 -
5.6gb mp4 file. Will i have to split it to watch on xbox?
By Cornholio77 in forum Video ConversionReplies: 27Last Post: 11th Apr 2014, 14:09 -
Split mp4 and Save to new folder
By scarymyth in forum LinuxReplies: 2Last Post: 22nd Feb 2012, 14:16 -
How do I split a MP4 VID?
By Soccerman77 in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 08:04 -
tool to split MP4 into 10 min segments for youtube?
By sdsumike619 in forum EditingReplies: 6Last Post: 31st May 2009, 15:18
